Options with Nvidia graphics card
  • davexnet
    • Mar 2013
    • 8
    Hi all -
    purchased a used Nvidia 6200 AGP video card from Ebay;
    pretty basic card - wanted to put it in an old Dell Dimension I picked up
    with Windows 7 installed. The existing card, Nvidia FX5200 doesn't support
    windows 7 (stuck on standard VGA mode)
    I paid $15 for it, including shipping, but I'm surprised and dismayed to
    see 6 bulging and leaking capacitors. I think they're Sacon, silver
    with blue on the top. The numbers say FZ73, 1000, 6.3 volt.
    The card is otherwise clean. Worth repairing? Or contact the seller and send it back?
    If it's worth repairing, any advice regarding replacements would be appreciated.
    Thanks,
    Dave
  • mockingbird
    • Dec 2008
    • 5484
    Re: Options with Nvidia graphics card
    FX5200 is supported on Windows 7 and Aero should work with it as well...
    Run Microsoft Update, it should find the driver.
    • Heihachi_73
      • Jun 2012
      • 713
      Yes, Sacon FZ are down there with Rulycon on the Badcaps shitlist. If you really want the card, it might be worth recapping, and hopefully the card itself hasn't been trashed due to the caps.
      As for Windows 7, it's not really Microsoft's fault if Nvidia won't let them use a generic driver for their video cards, or even offer support themselves for modern operating systems (Windows XP is over ten years old, and 32-bit CPUs are all but history). Nvidia won't even open source drivers for the Linux community, even for older cards (hope you have a Riva TNT lying around, as that's probably the only thing that will somewhat work out of the box, what a joke). Nvidia is practically the KFC of the graphics card world.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Work it out with the eBay seller, could have been an honest mistake in which case they'll probably refund you. I bought a router, and when it arrived it had obvious damage (not caused by shipping) and they were very apologetic and refunded me. And I got to keep it anyway,
        Then take the money, buy soldering iron, solder, caps, and fix it
        • davexnet
          • Mar 2013
          • 8
          Thanks for all the responses. I'm pretty good with a soldering iron, I have all the
          equipment - that's why I considered a repair Vs. a return. To be fair, it is probably
          an honest mistake by the seller. It's not glaringly obvious with a quick glance.
          But if you look closely, you can see the bulge (on all 6 of the 6.3v caps)
          and the brown stuff coming out.
          Regarding mockingbirds comment re: the driver, on the Nvidia website the only driver
          available for download is Forceware 96.85 and that's Vista only! For 7,
          nothing comes up. I did install this Vista driver. It actually installs -
          however, the Nvidia control panel doesn't work, and my monitors resolution
          is not available (1680 by 1050).
          Are you saying to uninstall the standard VGA from device manager,
          re-boot and allow the system to redetect?
          Certainly, going into Windowsupdate now (in standard VGA mode),
          nothing shows up for it.
          • davexnet
            • Mar 2013
            • 8
            Hi all - I tried to edit the previous message, but I couldn't find the edit button.
            The whole thing is moot now, I put the card in the Dell, no picture on the screen at all.
            Reseated it, but it's no-go. Seems as if I have to arrange a refund and return.
            I put back the old FX5200 and all is well again.
            Thanks for the comments!
            Dave
            • cheapie
              null
              • Jul 2010
              • 849
              It's in the bottom right, next to quote.
              Dave
              Probably because of the bad caps...
              • c_hegge
                • Sep 2009
                • 5219
                You can't edit a post more than 1 hour old here. The edit button disappears.
                  master hoarder
                  • May 2008
                  • 12175
                  The 6200 isn't all that much better than the FX5200, but I'd still repair it anyways. High chances it will work just fine with new caps. Need to get rid of all of the FZ caps, though.
                  • davexnet
                    • Mar 2013
                    • 8
                    Thanks for your comments and perspectives. I have my refund in hand,
                    as well as the card. The card, as-is, is dead - but as a project, I might replace
                    the caps and see if it brings it back to life.
                    Currently, there are 5 blown caps marked FZ73, 1000, 6.3v and one cap that
                    looks OK (same brand) marked FZ75, 470, 16v. Might as well replace all six.
                    Anybody have any specific recommendations on replacements?
                    I might also look around on Ebay and attempt to get another card. The PC I'm
                    matching it up with is a Dell Dimension, 2.80 GHZ single core Pentium 4,
                    2 GB PC3200 DDR1 RAM. I know the Nvidia 6200 is a pretty basic card.
                    If anybody has a suggestions of alternate AGP card to keep an eye out for,
                    I'd appreciate that too.
                    cheers -
                    Dave
                    • Northeastern292
                      • Jul 2009
                      • 15
                      Recaps on GPU boards are a miss on the one opportunity I've had. The one I have freezes up ever after the recap. But I wish you luck nonetheless!
                        Acer Aspire A517-51G-54J9 + Options Pack 17 Notebook 5 Specification for Upgrade or Repair
                        This specification for the Acer Aspire A517-51G-54J9 + Options Pack 17 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-51G-54J9 + Options Pack 17 boardview and A517-51G-54J9 + Options Pack 17 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                        09-06-2024, 08:47 AM
                        Acer Aspire A315-53G-53XW + Options Pack 15.6 Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Aspire A315-53G-53XW + Options Pack 15.6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-53G-53XW + Options Pack 15.6 boardview and A315-53G-53XW + Options Pack 15.6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        Acer Aspire VX5-591G-52MP + Options Pack 15.6 Notebook VX 15 Specification for Upgrade or Repair
                        This specification for the Acer Aspire VX5-591G-52MP + Options Pack 15.6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VX5-591G-52MP + Options Pack 15.6 boardview and VX5-591G-52MP + Options Pack 15.6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                        Acer Predator PH317-52-75DB + Options Pack 17 Notebook Helios 300 Specification for Upgrade or Repair
                        This specification for the Acer Predator PH317-52-75DB + Options Pack 17 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-52-75DB + Options Pack 17 boardview and PH317-52-75DB + Options Pack 17 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                        Acer Predator PH315-51-7075 + Options Pack 15.6 Notebook Helios 300 Specification for Upgrade or Repair
                        This specification for the Acer Predator PH315-51-7075 + Options Pack 15.6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH315-51-7075 + Options Pack 15.6 boardview and PH315-51-7075 + Options Pack 15.6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
