Nichicon HE caps
  • auxie22
    Nichicon HE caps
    Has anyone used these caps and are they good? The ones I was looking at looked good, i'm making a beefy psu with a few 25V 4700uF caps. The specs look great as they are rated at 0.012 ESR and 4220 Ripple. Hopefully I have read those right
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: Nichicon HE caps
    Assuming you have genuine Nichicon HEs, they are excellent. Not the absolute lowest impedance, but very close and their rated life is far higher than the lowest impedance parts. I'd also consider United Chemicon (Nippon Chemicon) KZE, HY and Rubycon ZL series to be of similar high quality.
    PeteS in CA
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      And Chemicon KY
      • jetadm123
        • 2169
        HY series?
        • mockingbird
          • Dec 2008
          • 5484
          ZL, KZE are one step up
          HE is equivalent to KY
          At 25V 4700uF, you could probably do very well with even PW/FC series since the ESR tends to get so low at higher values.
          • PeteS in CA
            • Aug 2005
            • 3579
            "HY" was a typo. I meant KY. KZE and ZL are a step lower in impedance and equivalent to HD IIRC. But they are also 5000 hour series where HE and KY are 10,000 hour series. I haven't found HD to be as durable, but that's under very extreme testing and with just one set of samples.
            PeteS in CA
            • nick3092
              Mid/late 80's Nichicon Yellow Caps
              by nick3092
              I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
              08-28-2022, 03:56 PM
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
