ASUS P4T-E and heavy disk use
  • angrybrit
    • May 2004
    • 6
    I have an ASUS P4T-E and it's getting flaky. Some weeks the system runs fine. Other weeks, it will reboot or freeze by itself frequently. I have not run a full Diskeeper on my HDs for a while. If I do, it's a garanted reboot. It will never get through. Last month, for 2 straight days, I had to press the RESET button for the IDE devices to be properly detected. Each time it took like 5 tries just to get them to identify them on the boot up sequence. There was one day, the computer didn't wanna boot up period. Almost each day I have to press RESET at least once just to get the IDE devices to be properly detected. :x
    At first, I thought it was the HDs that were giving the computer some trouble. Both Maxtors were swapped and work fine. I removed 2 DIMMs and let the system work on 256 Megs. Did the reverse for the 2 other DIMMs. I bought a new ANTEC power supply (350 watts) to replace the older Antec power supply (250 watts). Removed all unnecessarty peripherals. Problem still there. I am hopeless. About a week ago, I was reading some forum and people kept talking about how good the quality of the capacitors were on some XYZ mobo.
    I opened my PC and took out the mobo. The capacitors seem fine. Some are a little tilted. But there doesn't look like there are some leaking or a puffy top. Is there anything I am overlooking?
    I don't wanna replace my mobo and have to buy new memory. :|
    Here are my system specs:
    P4 1.7GHz (Willamette)
    512 RDRAM (non-ECC, 4 DIMMs x128 Megs)
    ASUS P4T-E mobo with latest BIOS 1.007
    MSI GeForce 5200 with 128 Megs RAM.
    - Ronald
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Welcome to the boards...
    What you're describing is a tell-tale sign of bad capacitors. Asus used quite a few brands of caps, some known to fail. Look at your actual caps and post the brands. This info will help in diagnosing. I understand you not wanting to replace the board/RAM, for what you probably paid for the RDRAM.
    Capacitors don't always leak and bulge when they go bad.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • angrybrit
      • May 2004
      • 6
      Here's the list of capacitors:
      Taicon
      green - 1500
      black/blue - 3300
      black/blue - 1500
      black/blue - 100
      black/gold - 1500
      Sanyo
      green - 1000
      purple - 510
      I am having difficulties getting pics of the mobo up.
      I tried to switch the RIMMs again and see if some are bad but it does the same problem when running Sandra (instant reboot).
      EDIT:
      1st
      2nd
      3rd
      - Ronald
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Run Memtest86, because you possibly have a RAM problem and the capacitors possibly aren't faulty.
        http://memtest86.com
        BTW, were there any errors in the event log about a crash, a stop error?
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • angrybrit
          • May 2004
          • 6
          It was my first stop (Memtest86).
          A month ago, I got a bad transfer (corrupt data) from 1 HD to another HD.
          I also have a known offender, TEAPO caps on my board. But they're small and not very numerous. Could this be the culprit?
          - Ronald
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            try a cable from a known working box.
            the 80 wire ide cables are fragile and i see plenty that have been damaged.
            • angrybrit
              • May 2004
              • 6
              Already changed them from normal IDE cable to rounded IDE cable. And the system is unstable on both cables.
              - Ronald
              • RJARRRPCGP
                • Jul 2004
                • 6304
                When the PC reboots on you, after reloading Windows, do you get any entries in the event log that at least looks similar to:
                The computer has rebooted from a bugcheck. The bugcheck was: 0x00000050 (0xf0006a70, 0x00000000, 0x00000000, 0x00000000).
                Arc A770 16 GB
                • angrybrit
                  • May 2004
                  • 6
                  I get a window that says that Windows encountered a serious error. :|
                  - Ronald
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    That means you got a BSOD, a stop error. To make Windows XP display a BSOD, do the following:
                    Go to Control Panel>Performance and Maintenance>System>Advanced>Startup and Recovery, click Settings, then uncheck "Automatically restart".
                    Then, you probably will see a BSOD, next time Windows XP crashes instead of a spontaneous reboot.
                    Arc A770 16 GB
                    • angrybrit
                      • May 2004
                      • 6
                      Thank you for the BSOD tip.
                      There was a problem with the IdeChnDr.sys file which comes from Intel's IAA drivers. Did a quick google and the first suggestion was check the HDs for bad clusters.
                      We'll the culprit was bad clusters. -_- :oops:
                      I ran the Maxtor utility, on both HDs, and it fixed all those bad clusters.
                      And then I tried to run a Defrag and it went all the way to the end!!! :P
                      Then I also did a full av scan and it went well too. No more reboots.
                      And I discovered another thing: the PC components are overheating inside my PC case from lack of airflow. Since I opened my case, no more missing ATAPI/IDE drives on bootup.
                      ScreenShot 1
                      ScreenShot 2
                      ScreenShot 3
                      EDIT: Under heavy disk usage last night, there was some beeping from the PC. The mouse was locked and PC was locked up. I waited aboot a min and the PC became responsivea again. Anything I should be worried aboot?
                      - Ronald
