Magnavox lcd tv capacitor help!!
  • rushgsxr
    • Oct 2012
    • 5
    • United state
    First off, I hope this is in the correct place in the forum. My apologies if not.
    Secondly, I was recently given a 37 in Magnavox LCD tv. Manufactured in 2006, model number 37mf331d. The previous owner was complaining sometimes it took a long time to start up and just bought a new tv and gave this one to me. So after some research I found that capacitors in the PSU often go bad, causing the issue. When I ripped it apart, sure enough a couple caps were bad. Venting out the top. So I'm hoping I can just replace them and have myself a nice tv for the basement. What I need your assistance for is finding the correct replacement capacitors.
    There's 2 CapXon that are bad, and 2 that I figure I will just replace, because I hear they're not the best and will go bad sooner of later. The first one is a 1200 uF 35V (105 degrees C) P616. Not sure what the last number is, but maybe its useful. The 2nd is a 2200 uF 25V (105 degrees C) P608. And the last 2 are 1000uF 35V (105 degress C) P620.
    I looked all over, but there's so many choices I have no idea where to start. If you need any more information let me know. Any help would be appreciated. Thanks!!
    Sam
  • Agent24
    I see dead caps
    • Oct 2007
    • 4963
    • New Zealand
    Re: Magnavox lcd tv capacitor help!!
    First of all you need some more information, specifically the series of capacitor. Then you can look up ESR.
    The capacitors should have on them a two-letter (sometimes three letter) code, this is the series designator.
    Then, you can look up the series. For your CapXon that would be here: http://www.capxongroup.com/en/prod_all_cat_full.aspx and determine the ESR and ripple handling.
    After that, find replacements from a reputable brand which meet the specifications.
    ESR should be same but usually there are no problems if it is slightly lower.
    Ripple and Voltage should be the same or higher, Capacitance you should generally leave as is.
    -David VanHorn
    • mariushm
      • May 2011
      • 3799
      If you can, post pictures please, as clear as possible. Use macro mode if needed.
      There may be other capacitors which are bad but you may not have noticed them.
      For example there may be a capacitor that's small in value, something like 10uF - 47uF which is too small to bloat but quite often goes bad in power supplies.
      If you write down what's written on those capacitors (besides the uF and voltage value) we may suggest more suitable capacitors instead of a "template", safe answer.
      Oh, and diameter and height of the old capacitors is important, if there is little room around them to insert larger or taller capacitors.
      It's possible to determine diameter and height if it happens to be a common manufacturer and series and we have datasheet, but you have to say what's written on them
      • rushgsxr
        • Oct 2012
        • 5
        • United state
        Couldn't get the best pictures but hopefully you'll see enough. I found a 2 digit code on them, LZ. The 1200uF 35V capacitor has a diameter of 13mm and height of 32mm.
        The 2200 uF 25V has diameter of 13mm and height of 25mm.
        The 2 1000 uF 35V capacitors have a diameter of 13mm and height of 25mm.
        Any other specs you need? Thanks!
        images
        online photo sharing
        • Agent24
          I see dead caps
          • Oct 2007
          • 4963
          • New Zealand
          Datasheet is here but not all your values are listed. Probably they are non-standard.
          If you have non-standard values the trick is to match the case size to determine approximate ESR and RCR.
          In all cases for your listed measurements the ESR is about 0.015 Ohm and RCR 2800mA.
          -David VanHorn
          • rushgsxr
            • Oct 2012
            • 5
            • United state
            The case sizes aren't similar for any of them?
            • rushgsxr
              • Oct 2012
              • 5
              • United state
              well, I found a kit online at lcdalternatives. They're sending me all the capacitors in the power supply, so I should be good to go.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4963
                • New Zealand
                Looks good, will be interesting to know what they give you.
                -David VanHorn
                • ryan74
                  • Oct 2012
                  • 471
                  • usa
                  i have ordered from lcdalternatives. they use good parts and it saves time looking up each individual cap and cost about the same.
                  • rushgsxr
                    • Oct 2012
                    • 5
                    • United state
                    16 bucks shipped, hopefully i get it this week, i'll let ya know how it goes.
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                    • chth96
                      How can I test non-polarized capacitor?
                      by chth96
                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                      06-02-2024, 07:31 PM
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
                    • chth96
                      Should I replace polymer capacitor?
                      by chth96
                      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                      Is this ESR value of polymer capacitor correct?...
                      11-18-2022, 04:22 AM
