bulging caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: bulging caps
    Yes. Polarity reversed on a polarized lytic destroys it immediately. They usually go out with a bang though....but if there's little voltage on it, it would just bloat.
    Those caps are 100% garbage and fake. Next time, try this:
    https://www.badcaps.net/store/produc...roducts_id=127
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • nick3092
      Mid/late 80's Nichicon Yellow Caps
      by nick3092
      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
      08-28-2022, 03:56 PM
    • re-atari
      Denon AVR-X2000 mainboard caps bulging
      by re-atari
      I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
      I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
      09-23-2020, 10:37 AM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
