VA902b Shakey jittery image
  • blues
    • Apr 2012
    • 19
    • CAN
    Re: VA902b Shakey jittery image
    I get it. Looked at digikey to see what info is there about the part, but was unable to find voltage regulator. What category should I be looking under? By the way, thank you for your help thus far, you have been invaluable, much appreciated.
    • retiredcaps
      • Apr 2010
      • 9271
      This should work.
      http://search.digikey.com/us/en/prod...9-5-ND/2472287
      Get 2 just in case one is bad or you make a mistake so you don't have to pay the $8 shipping/handling again.
      --- begin sig file ---
      --- end sig file ---
      • blues
        • Apr 2012
        • 19
        • CAN
        Thanks, your help is much appreciated. I looked at digikey and mouser and I cannot find the voltage regulator category. What should I be looking for?
        • retiredcaps
          • Apr 2010
          • 9271
          http://search.digikey.com/us/en/cat/...ors-linear-ldo
          • blues
            • Apr 2012
            • 19
            • CAN
            I received my part today and am about to try to uninstall the old IC voltage regulator. I am new and this and need some tips here. Are there four points of contact to the circuit board of just the 3 pins? How should I approach unsoldiering the old one?
            • jetadm123
              • 2169
              #26
              1) hopefully, you have at least a 40W soldering iron.
              2) with small diagonal wire cutters, cut each of the 3 legs all the way through. Using your soldering iron, heat up one of of the legs and remove it with a pair of small pliers or tweezers. Do the same for the other 2 legs.
              3) the tab is the hardest, since it requires the most heat to remove. With your soldering tip held against the tab, use your pliers to grasp the plastic body of regulator. When it looks like the solder is starting to melt under the tab, apply a very gentle twisting motion to the pliers. This should hopefully free the regulator from the board. If the solder is not melting, apply a little of your 60/40 solder to the tab, which should lower the melting point of the lead free solder underneath the tab.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #27
                It sometimes helps to heat the general area you are working on with a hair dryer so the heat from your iron isnt dissipated so quickly.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  Since I can't justify buying a hot air rework station, I borrowed a heat gun from my friend and have been experimenting with it removing smd components like sot-223 voltage regulators off old junk boards.
                  It works great, but there is no fine level control with the heat gun. So I ordered some Kapton tape and plan to cover up all the area to protect the other components from the heat.
                  I also plan to remove any capacitors that are close by in advance so they don't get killed by the heat.
                  • blues
                    • Apr 2012
                    • 19
                    • CAN
                    #29
                    Thanks, very helpful. My eagerness may have gotten me into trouble. I think I may have damaged the resistor above it, see post #13 for a picture of the resistor. I damaged the outer coating. Will this need to be replaced and does anyone know what type and value resistor I need?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      From the picture, it looks like white, brown, gold, gold so according to
                      http://www.hobby-hour.com/electronic...calculator.php
                      that is 9.1 ohms 5%. I would measure it and see if it is close to 9.1 ohms or not.
                      Since this is a low ohm resistor, touch your leads of the multimeter together. It should read around 0.2 to 0.3 ohms. If you reading of the resistor is 9.3 or 9.4 ohms, then the actual reading will be 9.1 ohms taking the resistance of the leads into account.
                      • blues
                        • Apr 2012
                        • 19
                        • CAN
                        #31
                        I think it looks more grey than white. I will need to follow your advice and meter it when I get home today. I read it as Grey, Red, Gold, Gold but from the picture it is hard to tell. Will als try to post a new picture later.
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #32
                          Id say white brown gold gold from ebay pic http://www.auctiva.com/hostedimages/...0,0,0&format=0
                          • jetadm123
                            • 2169
                            #33
                            If you scraped off some of the outer coating, it should still be ok. Do a quick check with your ohm meter. It's not the most accurate check, since the resistor is still in the circuit and you could be reading the resistance of other components, but still worth a try.
                            • blues
                              • Apr 2012
                              • 19
                              • CAN
                              #34
                              OK. I nmanaged to get the voltage regulator off as instructed by jetadm123 and then I installed the new one. I checked with my meter and got...
                              Pin3 5.00 VDC
                              Pin2 1.80 VDC
                              pin1 0.00 VDC
                              which was correct. I metered the ohms on the resistor and got 009, was 000 just touching the pos and neg together without anything in between, so I thought it was worth assembling and testing. To my surprise the no signal message was steady so I hooked up the monitor to a laptop and to my wonderment, the problem is solved. No more shakey jittery video. I am not to sure about my soldering, but hopefully it holds and will get better with time. Some assembly required.
                              Props to retiredcaps, selldoor and jetadm123, I couldn't have done it without you. You guys rock and so does this forum! You made a believer out of me, thanks!
                                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:20 PM
                                HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                09-06-2024, 10:56 AM
                                HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
