I would like to replace g-luxon 100uf 16v caps. I have the fx model. Please advise on a proper replacement. Thanks in advance.
replacement for g-luxon 100uf 16v
Re: replacement for g-luxon 100uf 16v
Well, they're 100uF , 16v , 6.3x5 mm 85mA ripple...
You didn't say if you have room for bigger height so I'm gonna list them by low height first
if you're in US, digikey is your best afaik:
http://search.digikey.com/scripts/Dk...name=P11198-ND (11mm tall but good specs)
http://search.digikey.com/scripts/Dk...l&name=P833-ND
http://search.digikey.com/scripts/Dk...USR1C101MDD-ND
http://search.digikey.com/scripts/Dk...me=493-3271-ND
in europe you have farnell.com:
http://uk.farnell.com/rubycon/16ml10...16v/dp/8126240
http://uk.farnell.com/rubycon/16yxf1...16v/dp/1144614 11mm tall
http://uk.farnell.com/panasonic/eeuf...0uf/dp/1848428 11.2mm tall
and others.. you may also get larger caps if you have room on the board...
both sites have the info listed for each one so you look for other caps -
Thanks for the quick reply. Is the voltage range not a factor when purchasing a replacement? The g-luxon has a range of 4-50vdc. The digikey site does not show this unless I'm not reading it right.
I found these but the range is 6.3-50vdc
http://www.newark.com/rubycon/16mh51...ial/dp/39T8540Comment
The voltage range of a capacitor series is not important - the voltage said on the capacitor is.
The replacement capacitor must be capable of handling at least the voltage of the old one - if it's rated for more it's OK and sometimes people replace capacitors with higher voltage ones because they have better tech specs but in your case it won't make a difference.
ps. the one you linked is not good enough. If you check the datasheet, you'll notice it can't handle as much ripple as the old capacitor was rated for. It can only do 62mA while the g-luxons are supposed to handle 85mA. They may work well or may die in a few months/years if you use it.Last edited by mariushm; 09-07-2011, 05:08 PM.Comment
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... -
by ezeniaHello,
Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,... -
by boosti45i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
by r2digitalI have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...2 Photos
- Loading...
