More video card fun
  • wapacz
    • Sep 2011
    • 3
    More video card fun
    I have a fx5500 in basically my file server that has blown a cap. From a bit a research around here it seems the caps are the sacon brand that seems to love to die. So here I am trying to figure a suitable replacement. The caps are fz5c 16 volts 1000 micro F. From some data sheet I came across it lists the impedance at 21 ohms and ripple current at 1.79 amps.
    Based off matching those specs I came across http://www.chemi-con.com/index.php?o...s&product=2772 which is 16 volt 1000 micro F impedance of 23 ohms and ripple current of 1.82. It is 8 mm taller but that is fine with me as there is an open card space below it so its not going to work for me.
    So the basic question is will that work or are there any recommendations that will work.
  • mariushm
    • May 2011
    • 3799
    Re: More video card fun
    I think these should work :
    http://search.digikey.com/scripts/Dk...name=P12366-ND
    http://search.digikey.com/scripts/Dk...me=565-1664-ND
    http://search.digikey.com/scripts/Dk...UHM1C102MPD-ND
    The second is probably the one in your link.
    If you're in Europe, at least one of the above should be available on farnell.com
    • wapacz
      • Sep 2011
      • 3
      Thanks and i'm in the US. Guess I should add that to my profile.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Just FYI: the Ripple on those FZ is 1800 mA and ESR is .022 ohms.
        All of those caps will work.
        If height is an issue the HM is only 16mm tall vs 20mm for the other two.
        Mann-Made Global Warming.
        - Dr Seuss
        • wapacz
          • Sep 2011
          • 3
          no height problems as I have an open pci slot below the card.
