Recapping question
  • djester55
    • Dec 2010
    Recapping question
    I'am about to replace 5 caps on my inverter board for my lcd screen. The question i have is about the caps i got.The five caps i'am replacing are Samxon
    1000uf25v 1
    1000uf16v 2
    680uf25v 2
    The new caps i got are nichicon and it seems like 680uf25v caps i got are taller then the old ones and the 1000uf16v are shorter then the old ones i am replacing. Is it ok to use them?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Recapping question
    Are the old ones Samxon GF series?
    You can use different height and diameter caps as long as it can fit. You don't want to end up like
    https://www.badcaps.net/forum/attach...4&d=1257960610
    --- begin sig file ---
    --- end sig file ---
    • djester55
      • Dec 2010
      yep the old ones are the GF series
      • retiredcaps
        • Apr 2010
        • 9271
        It seems that Samxon GF are turning out to be duds. I have a couple that are dated 2008 and failed after 2 years.
        • djester55
          • Dec 2010
          Thank you for your help. I just put them in and they work
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
