so i got the meter today and went on testing a few bad projector psu's i had waiting to be fixed. all caps had an esr rating well below the limit but there were a couple that were pretty much right at the line and one way higher than it should be indicating a bad cap. but what about the ones that are right on or close to the limit line. do these need replaced?...at what point does a cap esr reading warrant a bad cap?...anything over the line?...anything close to the line?...also i read somewhere here on the forum about replacing caps with other caps that arnt the exact same value...i wasnt able to find this thread again but is there some rule to follow when doing this or a chart i can consult?..thanks for any and all responses and i look forward to cruisin the forums with you guys as i plan on bein around a while as i dive deeper into this electronics repair venture
just got my blue meter...have a couple questions
Tags: None
Re: just got my blue meter...have a couple questions
I would suggest that if the ESR shown on the meter is more than 70% of the "limit", then that cap should be replaced.so i got the meter today and went on testing a few bad projector psu's i had waiting to be fixed. all caps had an esr rating well below the limit but there were a couple that were pretty much right at the line and one way higher than it should be indicating a bad cap. but what about the ones that are right on or close to the limit line. do these need replaced?...at what point does a cap esr reading warrant a bad cap?..
Anything at or near the limit is toast. The cap still works, but it is putting an unnecessary load on the system.
A fully recapped board works SO much better than one with semi-okay caps. -
got it thanks...then thats what ill do. also...any tips getting an esr reading on caps over 250v?I would suggest that if the ESR shown on the meter is more than 70% of the "limit", then that cap should be replaced.
A fully recapped board works SO much better than one with semi-okay caps.Comment
ESR in data sheets is given as a specific value, so where are you coming up with some range that has a limit?so i got the meter today and went on testing a few bad projector psu's i had waiting to be fixed. all caps had an esr rating well below the limit but there were a couple that were pretty much right at the line and one way higher than it should be indicating a bad cap. but what about the ones that are right on or close to the limit line. do these need replaced?...at what point does a cap esr reading warrant a bad cap?...anything over the line?...anything close to the line?...also i read somewhere here on the forum about replacing caps with other caps that arnt the exact same value...i wasnt able to find this thread again but is there some rule to follow when doing this or a chart i can consult?..thanks for any and all responses and i look forward to cruisin the forums with you guys as i plan on bein around a while as i dive deeper into this electronics repair venture
[Just asking...]
Also note that the ESR given in data sheets is the worst case where the cap is considered to be within factory specs.
Caps [especially new ones] with ESR a bit lower than shown in their data sheets is quite normal.
[This applies to Low ESR caps.]
Those few manufacturers that say anything about it consider caps failed if ESR has doubled.
While that might be true when considering only the cap, that doesn't mean a given circuit will work right if the cap's ESR doubles.
.Last edited by PCBONEZ; 11-17-2010, 08:55 PM.Mann-Made Global Warming.
- Dr Seuss
I suspect he is referring to the table of UF value, voltage, and maximum ESR that comes with ESR meters, intended as a general guideline. I know the Blue meter has such a chart, I've seen references to it here. I don't have the Blue meter, but my meter has such a chart on the front face of the meter.
Not perfect at all, but gives a definite idea of the scope of the recapping job
required. If at a minimum, you were to replace all the caps that are suspect, you would reasonably expect the board to boot and load an operating system.Comment
AFAIK those charts are based on GP caps as in TV sets and so forth.I suspect he is referring to the table of UF value, voltage, and maximum ESR that comes with ESR meters, intended as a general guideline. I know the Blue meter has such a chart, I've seen references to it here. I don't have the Blue meter, but my meter has such a chart on the front face of the meter.
Not useful for Low ESR caps at all.
Also the +/-20% Tolerance stated for caps only applies to the uF.
- Dr Seuss
Is this bluemeter the same as Rusmike's meter? What are your opinions on multimeters that have built-in capacitance testing. Crude, perhaps, but is it useful at all?Comment
They are both based on [reworks of] Bob Parker's ESR meter.
AKAIK insofar as the ESR function the only differences are kind of leads and cosmetics.
I have one of Bob Parker's Mk-II version which I prefer as the leads connect via banana plugs so I can change leads when I feel the need.
"multimeters that have built-in capacitance testing"
I've never had one as I have a few actual capacitance meters around.
From what I've seen most don't have much of a uF range.
If you can find one with an appropriate range I imagine they are fine.
- Dr Seuss
The only DMMs with decent uf range capacitance functions are the high end (non graphing) Flukes my 87-5 can do up to 9,999uf at 1% accuracy. I'm curious what the accuracy of Rusmikes is? I'm not talking it down just curious.
During my DMM purchase research earlier this year. I quickly discovered how most meters had very low capacitance ranges some maxed out in the high pF range while others went to a whopping 10uf.
I came to the conclusion that unless you're willing to shell out big bucks for a DMM with a large capacitance range you're looking at either a used LCR meter or a homebrew rig if you need capacitance.
On the usefulness of a cap meter. Occasionally a caps ESR can be fine but it's capacitance can drop this is where a cap meter would be more useful however this occurrence is fairly rare.
On the the usefulness of the meters with the max capacitance in the pF range I personally find them useless. Because in most cases the caps with these tiny values are virtually trouble free.Last edited by Krankshaft; 11-19-2010, 02:59 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
$320 for that model, I checked... I would rather have ESR measurement than capacitance for sensitive applications, but I can see where capacitance measurement would be useful.Comment
This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:50 AM
This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
