Replacement cap help
  • aaronmarsh632
    • Nov 2010
    • 20
    I am wanting to replace a burst cap on a dell motherboard but i'm struggling to find a replacement.
    it is a - 820uf 6.3v diameter = 8mm length = 20mm
    please does anyone know where i can get 1 from (pref UK) or can I substitute it with something else?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Replacement cap help
    This is from digikey
    http://search.digikey.com/scripts/Dk...name=P12352-ND
    but Panasonic FM is widely available from the big UK internet sites.
    It is 8x15mm.
    Panasonic FM is low ESR cap.
    --- begin sig file ---
    --- end sig file ---
    • yyonline
      • Jul 2009
      • 692
      What grade is the original cap? Are there any other markings on it that would indicate its series?
      Rubycon/Nichicon/Chemicon made custom size "extra tall" 820uF caps for many P4-era boards. The custom size 820uF cap has lower ESR and higher ripple current limits than a normal 820uF cap. If your cap is one of these custom size ones, FM would be an inadequate replacement. They don't make the custom size any more, so you're left with the option to use a poly cap on it, or find some new old stock of the custom size capacitors.
      But...let's get more info about the original before jumping to that conclusion.
      • Teban1306
        [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
        by Teban1306
        Hello everyone!
        I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
        System Information:
        • Model: Lenovo ThinkPad T14 Gen 1
        • Machine Type: 20S1S4E600 (Intel i7 variant)
        • Current BIOS: N2XET42W (1.33) - Latest version
        • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
        What I'm trying to achieve:
        Replace the default "LENOVO" boot logo with a custom image during POST.
        🔧 What I've tried:
        09-14-2025, 11:49 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
