This can't be real
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: This can't be real
    I will post pictures when i finally get internet. Theu promised today but was a failure.
    • AdrenalinTL
      Macbook Pro A1707 - Dead - Battery 'popped'
      by AdrenalinTL
      Hi Peeps.
      Just a quick question please as I am by no means an Apple fundi at all.
      Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
      Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
      Don't want to go buy a battery for no reason.
      Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
      07-18-2024, 09:52 AM
    • Prosatanosz
      Asus B85M-GAMER no hdmi output and random restarts
      by Prosatanosz
      Hi!
      Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
      10-19-2024, 05:27 AM
    • cnti
      Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
      by cnti
      Hi.
      BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
      This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
      BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
      RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
      burned, measured 10M ohm.
      QM801 [real PSU:...
      10-19-2023, 05:33 PM
    • Dreigas
      Asus TUF Gaming FX506LX laptop just stuck at random time
      by Dreigas
      I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areas—about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
      One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
      07-27-2024, 05:58 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
