NVIDIA GeForce RTX 4060 (RTX4060Ti) Schematic & Board View
    The GeForce RTX 4060 is a performance-segment graphics card by NVIDIA, launched on May 18th, 2023. Built on the 5 nm process, and based on the AD107 graphics processor, in its AD107-400-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD107 graphics processor is an average sized chip with a die area of 159 mm² and 18,900 million transistors. It features 3072 shading units, 96 texture mapping units, and 48 ROPs. Also included are 96 tensor cores which help improve the speed of machine learning applications. The card also has 24 raytracing acceleration cores. NVIDIA has paired 8 GB GDDR6 memory with the GeForce RTX 4060, which are connected using a 128-bit memory interface. The GPU is operating at a frequency of 1830 MHz, which can be boosted up to 2460 MHz, memory is running at 2125 MHz (17 Gbps effective).
    Being a dual-slot card, the NVIDIA GeForce RTX 4060 draws power from 1x 12-pin power connector, with power draw rated at 115 W maximum. Display outputs include: 1x HDMI 2.1, 3x DisplayPort 1.4a. GeForce RTX 4060 is connected to the rest of the system using a PCI-Express 4.0 x8 interface. The card's dimensions are 240 mm x 111 mm x 40 mm, and it features a dual-slot cooling solution.
    RTX4060
    RTX4060Ti
    Hi, it is only a broadview. Where is the schematic?
      thank you broadview
