AMD Radeon RX 6700 XT (RX6700XT) Schematic & Board View
    The Radeon RX 6700 XT is a high-end graphics card by AMD, launched on March 3rd, 2021. Built on the 7 nm process, and based on the Navi 22 graphics processor, in its Navi 22 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6700 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 22 graphics processor is a large chip with a die area of 335 mm² and 17,200 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. The card also has 40 raytracing acceleration cores. AMD has paired 12 GB GDDR6 memory with the Radeon RX 6700 XT, which are connected using a 192-bit memory interface. The GPU is operating at a frequency of 2321 MHz, which can be boosted up to 2581 MHz, memory is running at 2000 MHz (16 Gbps effective).
    Being a dual-slot card, the AMD Radeon RX 6700 XT draws power from 1x 6-pin + 1x 8-pin power connector, with power draw rated at 230 W maximum. Display outputs include: 1x HDMI 2.1, 3x DisplayPort 1.4a. Radeon RX 6700 XT is connected to the rest of the system using a PCI-Express 4.0 x16 interface. The card's dimensions are 267 mm x 110 mm x 40 mm, and it features a dual-slot cooling solution.
    GV-R67XTGAMING
    GV-R67XTUD-12GD
    RX6800XT​
  • Much Bugs
    • Apr 2025
    • 37
    • China
    Another 6700xt BoardView of MSI😉
    • Vincenzo9901
      • Jan 2022
      • Italia
      Thanks guys.
      • LealEletronic
        • Mar 2025
        • 12
        • Brasil
        Hello guys.
        I'm looking for the boardview or schematics to RX6700XT Aorus Elite.
        Someone has it?
        • OACLWA500
          • Jun 2025
          • Peru
          Somebody has the sapphire RX6700XTNitro+?
          • AcidicRyu
            • Jul 2025
            • Philippines
            Hello guys.
            I'm looking for the boardview or schematics to Sapphire pulse RX6700XT.
            Someone has it?
            • striker16
              • Sep 2025
              • 6
              • Philippinesa
              Up for this.
              Thanks TS for other schematics
              • gerardo
                Engineer
                • Feb 2016
                • 60
                • Argentina
                • duc_tech
                  • Sep 2014
                  • 28
                  • Philippines
                  thanks a lot
                    AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                    The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                    10-01-2024, 12:46 PM
                    AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                    The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                    10-01-2024, 01:07 PM
                    AMD Radeon RX 470 / RX 580 Schematic & Board View
                    The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                    10-01-2024, 12:52 PM
                    AMD Radeon R7 340 / R7 430 Schematic & Board View
                    The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                    10-01-2024, 12:36 PM
                  • my2k2
                    Need: FXF Radeon RX 6700 XT MERC Schematic diagram
                    by my2k2
                    Good day to all.
                    Need FXF Radeon RX 6700 XT MERC Schematic diagram and Boardview?
                    Any help would be highly appreciated. Thanks in advance.
                    08-05-2023, 03:58 AM
