ISL84521IBZ ISL84521IVZ ISL84522IBZ ISL84522IVZ ISL84523IBZ ISL84524IUZ-T ISL84523IVZ ISL84524IUZ-T Datasheet
    • 115471
    Low-Voltage, Single and Dual Supply, Quad SPST, Analog Switches
    The Intersil ISL84521, ISL84523, ISL84523 devices are
    CMOS, precision, quad analog switches designed to operate
    from a single +2V to +12V supply or from a +2V to +6V supply.
    Targeted applications include battery powered equipment that
    benefit from the devices' low power consumption (<1uW), low
    leakage currents (1nA max), and fast switching speeds
    (tON = 45ns, tOFF = 15ns). A12 Ohm maximum RON flatness
    ensures signal fidelity, while channel-to-channel mismatch is
    guaranteed to be less than 4 Ohm.
    The ISL84521, ISL84522, ISL84523 are quad
    single-pole/ single-throw (SPST) devices. The ISL84521 has
    four normally closed (NC) switches; the ISL84522 has four
    normally open (NO) switches; the ISL84523 has two NO and
    two NC switches and can be used as a dual SPDT, or a dual
    2:1 multiplexer.
    For higher performance, pin compatible versions and 3mm x 3mm Quad
    No-Lead Flatpack (QFN) package see the ISL43140,
    ISL43142 data sheet.
    Features
    • Drop-in Replacements for MAX4521 - MAX4523
    • Four Separately Controlled SPST Switches
    • Pin Compatible with DG411, DG412, DG413
    • ON Resistance (RON Max.) . . . . . . . . . . . . . . . . . . . 100 Ohm
    • RON Matching Between Channels. . . . . . . . . . . . . . . . . . <1 Ohm
    • Low Power Consumption (PD). . . . . . . . . . . . . . . . . . . .<1uW
    • Low Leakage Current (Max at 85oC) . . . . . . . . . . . . 10nA
    • Fast Switching Action
    - tON . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45ns
    - tOFF . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15ns
    • Break before Make Timing
    • Minimum 2000V ESD Protection per Method 3015.7
    • TTL, CMOS Compatible
    • Pb-free available
    Applications
    • Battery Powered, Handheld, and Portable Equipment
    - Cellular/Mobile Phones
    - Pagers
    - Laptops, Notebooks, Palmtops
    • Communications Systems
    - Military Radios
    - RF "Tee" Switches
    • Test Equipment
    - Ultrasound
    - Electrocardiograph
    • Heads-Up Displays
    • Audio and Video Switching
    • General Purpose Circuits
    - +3V/+5V DACs and ADCs
    - Digital Filters
    - Operational Amplifier Gain Switching Networks
    - High Frequency Analog Switching
    - High Speed Multiplexing​
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
    DVR camera recorder switching power supply capacitor failure really
    by sam_sam_sam
    These cheap non brand capacitors at it again
    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
    Well at least I have the cameras back on line I to try the...
    01-22-2022, 06:28 PM
  • michel74
    How does this switching PS work ?
    by michel74
    Yes ! How does this switching PS works ? :-)
    I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
    Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
    11-02-2023, 12:35 PM
