Watch for 'unknown' chips in power supplies!
  • japlytic
    • Oct 2005
    • 2086
    In a few power supplies I have seen, there is a proprietory chip (usually the SMPS controller) in them. These supplies can be unreliable.
    They included an LC-B400ATX and similar models (with a chip simply marked '2003') and an LC-A400ATX (with a chip marked 'DR0183'). The proprietory chip in these supplies had no evidence of the markings being sanded off.
    The replacement power supply in my computer has a popular TL494 SMPS controller.
    You should be suspicious of power supplies having an proprietory SMPS chip , and only buy supplies with a well-known SMPS chip (eg. TL494/KA7500, SG/LT3524, SG/LT3525, UC3842 etc.)
    If you have any supplies with proprietory SMPS controllers (which you cannot identify the manufacturer of), please post it here!
  • PeteS in CA
    • Aug 2005
    • 3586
    • USA, Unsure of Planet
    Re: Watch for 'unknown' chips in power supplies!
    Both Delta Products (I used to work for them) and Astec, very good P/S mfrs, use in-house-design ASICs in some of their products. One of Delta's ASICs that I'm aware of combines a PFC controller and a PWM controller in one chip. The other Delta ASIC I've seen is a secondary-side supervisor, combining OVP, current limit, sequencing, and possibly the error amplifier in one chip. Custom isn't necessarily bad.
    PeteS in CA
    • japlytic
      • Oct 2005
      • 2086
      I have seen a custom chip in an Astec supply before.
      We should only avoid the not-so well-known manufacturers with power supplies containing custom chips (mainly Chinese), and if we do buy power supplies with custom chips, only buy them from the larger (and more well-known) manufacturers.
      • Newbie2
        • Sep 2005
        • 885
        I have seen a TL494 chip in a generic 250W PSU before, but I don't know if it's a genuine chip or a counterfiet that looks identical. Pics later.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • Rainbow
          • Aug 2005
          • 1375
          I see often Daewoo DBL494 which is TL494 compatible. I've bought some original TL494 for PSU repairs - they're cheap here.
          • linuxguru
            • Apr 2005
            • 1564
            TL494 or KA7500 are commodity parts with many second sources, and they're fairly rugged - I haven't seen a failure yet, though I suppose it does happen.
            • Rainbow
              • Aug 2005
              • 1375
              Yes, they're reliable. They fail only when the supply voltage goes too high - which happens when aux supply fails in some PSUs. Then usually some of the pins short to ground internally. If it happens when the power is on, it can easily damage other PC components.
              • Newbie2
                • Sep 2005
                • 885
                I just checked the chip in the generic 250W power supply and it was TL494CN.
                Plus I checked the chip in an Enermax EG301P-V 300W power supply and the chip was an ST LM339N chip.
                I discovered Digikey sells both of those chips, which is a relief for me.
                The only custom proprietary chip I saw was the ones in L&C power supplies.
                I couldn't get pics just because my camera doesn't have macro mode.
                My gaming PC:
                • PeteS in CA
                  • Aug 2005
                  • 3586
                  The LM339 is a quad comparator, a good GP jellybean part. Lots of companies make it; National Semiconductor designed it back in the 70s.
                  PeteS in CA
                  • yanz
                    • Nov 2004
                    • 910
                    My Aibo 360w PSU has a chip marked:
                    2003
                    BA110130431E
                    • linuxguru
                      • Apr 2005
                      • 1564
                      If it has a controller marked 2003, it's a Deer/L&C. The only saving grace is that lots of things tend to fail in a Deer before the controller fails - so the 2003 chip is usually OK.
