chieftec psu killing apc backups
  • i4004
    • Oct 2006
    • 2029
    the symptoms were relay arcing on the apc backups pro. it was producing the buzzing sound. while it was running off the batteries. output to load was ok in both cases, running off the mains or from the battery.
    so i take the backups apart and replace all 3 untransparent relays even though only one was damaged(the one in the middle). (i did the same for my smaller backups device, so i thought it should work here too...come to think of it on my backups symptoms were slightly different; buzzing and flickering the load(for example lightbulb hooked to it flickers) was happening even when it was on mains...first symptom was it suddenly gave up.
    otoh backups pro was not turning off the load or flickering it, it was just struggling...)
    then i got to play with outputs: i notice the following: no arcing buzz when pc is not connected.
    connect monitor, connect amp etc. it's ok, but as soon as you connect pc, it gets confused and it buzzes when running off the batteries.
    (smaller backups unit(like the one i have...300va) was shutting down when mains was disconnected....it was supposed to run from batteries but it would just shut down).
    then i remembered this psu has a-pfc, so i fetch p-pfc fortron and hook it up, and sure enough everything is back to normal, no buzzing when it's running off the batteries, and smaller backups unit is working as expected.
    the only explanation i came up with so far:
    a-pfc circuitry is somehow cycling the energy so that backups pro(650va, i think) is on the limit of what it can and can't do.
    at one moment load is acceptable, at another it goes over the top and then protection shuts it down.
    but this is happening at such frequency that it's destroying the relay rather fast. big arcs etc.
    smaller backups was not affected because it's weaker, it cannot provide enough energy at any point, it just shuts off immedietely and stays shut.
    the whole thing is probably connected to something we discussed earlier
    https://www.badcaps.net/forum/showth...&highlight=apc
    but it's not just that old design ups' can damage the psu, but some a-pfc designs can damage the ups units.
    huh...
    one backups 650 already paid this with its life. but perhaps i'll be fixing that one...it seems switchers (and offcourse relay) pay in the end.
    found this
    http://episteme.arstechnica.com/eve/...1#725004899831
    "Power fails
    UPS starts supplying square/jagged wave 'power'.
    PSU chokes and shuts down.
    UPS shuts down, since there is no load.
    (all happening within the first few milliseconds of the event)"
    that's consistant with what i've said, only in my situation ups is shuting down, but then turning on again, in rapid succesion.
    could probably be explained by psu choking and shutting down/powering up in a same manner.
    either way, a bad-bad a-pfc on that chieftec!
    this one
    https://www.badcaps.net/forum/showth...light=chieftec
    bad for these old apc backups anyway.
    backups pro
    http://www.apc.com/resource/include/...TOKEN=80837878
    (offourse, 230v model here)
    the one it already destroyed
    http://www.apcc.com/resource/include...se_sku=BK650MI
    something else i've found
    http://www.hardforum.com/showpost.ph...9&postcount=10
    apparently designing ups doesn't have much to do with trying them in the field...
    gee is one dumb bastard...but also a "professional"...huh...
    i should buy few more fortrons with p-pfc as sine wave ups are too expensive.
  • i4004
    • Oct 2006
    • 2029
    Re: chieftec psu killing apc backups
    one more interesting post
    http://www.silentpcreview.com/forums...a953d1b#392759
    and chieftec is delta.
    and given that i've replaced it with this
    https://www.badcaps.net/forum/showth...hlight=fortron
    it seems pnf is stil better than this delta with a-pfc..hehe...
    • piernov
      NVidia bumpgate
      by piernov
      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
      May complete this post at a later date with more details.
      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
      03-27-2021, 10:34 AM
    • socketa
      Corsair TX650W fuse, NTC thermistor, and (APFC? Power Transistor) fried
      by socketa
      I read through this thread, and just want to confirm what i should do.
      https://www.badcaps.net/forum/showth...hlight=24N60C3.
      This person's fault was exactly the same as mine, even down to the power strip and with the muffled popping sound.
      I suspect that my problem started with an old power strip, of which a computer and a 2000W heater were plugged into...
      I noticed melting and heat where the heater was plugged in, so i plugged the heater directly into a double wall socket, but still noticed the muffled pop sound when i turned on the computer, and...
      07-18-2021, 02:09 AM
    • grss1982
      PSU killing components?
      by grss1982
      Hi everyone! Been a while!
      So I have a CM MWE 750 Bronze - V2 PSU powering the following:
      Ryzen 5 3400G
      Gigabyte B450 Auorus Motherboard
      32GB DDR4-3600 (2x16)
      ASUS TUF 1660 TI 6GB DDR6
      1TB NVME
      This was purchased by a friend about 3 years ago for her kid and now it showing signs of instability. The PC had this problem of the screen becoming garbled after it was booted up and idling in Windows. It also sometimes gets a BSOD. So I did some stress test by starting with Prime 95 and noticed that the torture test just fails and stops immediately....
      01-17-2025, 04:12 AM
    • GnatGoSplat
      Antec BP500U APFC Coil
      by GnatGoSplat
      Antec BP500U PSU fried in my wife's gaming PC. I smelled something unpleasant last night, so I had a hunch something might be amiss. Woke up this morning to a popped breaker and immediately assumed the APFC cap must have blown. I last fixed it sometime in 2011, there's a thread about it here someplace. APFC and secondary caps that time. Replaced them with Panasonic caps. 10+yrs is probably a good run. It's been running 24/7 the last 3yrs, eth mining with a 1070ti and AFK fishing in Black Desert Online, lol.
      Anyway, cracked it open this morning, expecting it to just be the APFC cap...
      11-02-2021, 09:22 AM
    • nick122
      Chieftec (Delta) GPS-450AA-101 A repair and possible upgrade options?
      by nick122
      Hi everyone!
      I’m trying to diagnose (and perhaps even upgrade) this Chieftec (Delta rebrand) power supply from an old rig
      The computer just stopped turning on one day. No explosions, no magic smoke, it just died.
      There is no 5vsb, and nothing happens when I try to jump start it, it’s completely dead…
      I took it apart and nothing looks out of the ordinary. The fuse isn’t blown and the main cap gets charged (found out the hard way lol)
      The caps are mostly ltec with a samxon primary, none of which are bulging
      Any ideas what I should look...
      01-05-2025, 04:31 PM
