packard bell mit-rhea-c wifi problem
  • torla
    • 76
    packard bell Model: mit-rhea-c
    wifi problem cant turn on.
    Fn+f1 beep but not work.
    http://s9.postimg.org/fn00lpju6/010.jpg
    http://s9.postimg.org/x6o03noa6/011.jpg
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: packard bell mit-rhea-c wifi problem
    You can try flash the bios, if it not solved the problem, then reflow the southbridge,
    I need a schematic to make sure that it come from the south brigde.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • torla
      • 76
      bios update but not work. . .
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        maybe your keyboard is broken taste F1 tray any utilities of wifi you can find on packadbell support.
          • 31095
          use a Linux live-disk to check the hardware.
          • torla
            • 76
            FN and F1 Forking,
            When you press Fn + F1 hear a beep
            Video
            https://www.youtube.com/watch?v=iV2W...ature=youtu.be
              • 31095
              you need to test it with Linux to tell if it's hardware or a windows problem.
              • torla
                • 76
                not work, thx for help
                • Life Goes On
                  • May 2014
                  • 264
                  • Curacao
                  I think you need to install the windows again.
                  • maxlove70
                    Need Bios Packard Bell iSTART 2356
                    by maxlove70
                    Hello, I'm searching Bios for Packard Bell iSTART 2356.
                    Asus for Packard Bell M2NS-NVM (Boston) 0206 BIOS - 6A69NA01
                    Manufacturer and model: Asus for Packard Bell M2NS-NVM (Boston)
                    Chipset: AMD 1100
                    Part number: 6A69NA01
                    BIOS ID: 03/05/2007-NF-MCP61-M2NS-NVM-00
                    BIOS Release date: 2007-03-05
                    BIOS Revision: 0206
                    Packard Bell Support for this PC is discontinued.
                    Please Help Me !!!!
                    Thanks.
                    02-16-2023, 11:52 AM
                  • pkslowk
                    Debug Card Error Code and Solution
                    by pkslowk
                    Sr. Motherboard Debug Error Code Solution
                    1 Intel 845 E9 Bios Related Problem
                    2 Intel 845 D4 CPU Socket Related problem
                    3 Intel 845 37 Bios Related Problem
                    4 Intel 845 7C Bios Related Problem
                    5 Intel 945GCPE 34 Bios Related Problem
                    6 Gigabyte 845 2 Ram Related Problem
                    7 IBM Server A6 A7 Ram Mismatch Problem
                    8 Asus 845 29 CPU Related Problem
                    9 Lenovo I946 97 C-Mos Jumper related
                    10 Gigabyte 845 A0 CPU Related Problem
                    11 Asrock G31M-VS D7 Bios Related Problem
                    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                    01-28-2021, 12:51 PM
                  • dicky96
                    Packard Bell EasyNOTE TK backlight problem
                    by dicky96
                    Hi guys, I don't fix many laptops so I am not totally familiar with this fault
                    I have the Packard Bell EasyNOTE TK laptop
                    The fault is no backlight. I get a picture on an external monitor connected to either VGA or HDMI, and if I shine a torch on the laptop screen I can see I have an image but no back light.
                    The fault was initially intermittent, the laptop would work for 10 minutes after power on then the screen would go black. Sometimes it would last for a longer time, enough time to install windows and some apps, and then go black.
                    08-27-2021, 04:26 AM
                  • omaryou
                    PLS NEED TO UNLOCK OLD packard bell bios
                    by omaryou
                    PLS NEED TO UNLOCK OLD packard bell bios I can't find the File on the website of packard bell for this model
                    Packard Bell Easynote ALP-Horus G2...
                    06-20-2022, 07:11 PM
                    Packard Bell Easy Note EN TE11BZ Q5WT6 Laptop Schematic
                    LA-8531P Rev 0.3...
                    11-06-2024, 06:29 AM
