First of all, I'd like to thank the contributors to this site. I've learned a lot from this forum.
I have a Sharp Aquos LC-60LE810UN with a blank screen, 1 -1 error code(Lamp error) flashing when plugging in the TV. Not possible to get to the service menu or resetting the error via CH- and VOL+ when plugging in the TV. I've tried to replace all three boards to no avail(I am a novice). From this forum I learned it is either a LCD panel or backlight problem. So I took the panel apart, tested the LED strips, found 2 open LEDs which I replaced with diodes(1N4148). The panel's LED strip configuration is: 2 x 50-LED strips on top/bottom and 2 x 30-LED strips on each side.
I successfully tested the 30-LED strips with a battery pack of 10 x 9V batteries. For the 50-LED strips, I tested each LED individually(phew!).
So now I am assuming the backlight is ok, but I want to test it before assembling the panel. My test setup includes the chassis with LED strips installed, PSU/inverter combo board with BU5V(standby) jumped to PS_ON and PNL_POW via a 1K resistor. However, the backlights do not light up. When I measure the LED driver voltages(between LED_DRV1+ and LED_DRV1- and so on), I get ~27VDC - 25VDC for each LED driver. Each LED driver powers 80 LEDs, so I would expect over 240VDC. Any pointers as to how to proceed from here?
