Matsonic MS8318E Motherboards
  • skydiver
    • Jul 2004
    • 3
    Hello all:
    I have had three of four installed Matsonic Motherboards fail in the last month. They all had the same symptoms: The systems started to constantly reboot, followed by complete failure to POST. One of the systems actually popped and left an ozone smell in the office.
    My questions is whether I should replace ALL the capacitors on these failed boards or just the capacitors of the same size and manufacture as the capacitors which failed and are bulging on top? The capacitors that look like they failed are purple with gold printing. They are marked RLX 105 C 0206. They have what looks like a manufaturer name of OST above a label I.Q. 6.3v 3300 micro farads rating. Each board has 8 of these capacitors of which an average of 5 have visibly failed. Each board has another 7 green with silver print G-Luxon 6.3v 1500 capicitors none of which have apeared to have failed, 4 Black/White print G-Luxon 1000, capacitors, and a multide of smaller G-Luxon capictors none of which appear to have failed.
    Please let me know what I should do here. I would love to be able to salvage a couple of these boards for backup since the computers that they came out of have since had new MBs installed.
    BTW, I am especially dismayed at the horrendous customer support that I recieved from Matsonic. I actually had a guy in their LA office hang up on me when I asked to speak to his superior when all he would do is quote their policy that they only support their customers, not end users. I will never again buy ANYTHING from them again.
    Skydiver
  • skydiver
    • Jul 2004
    • 3
    Matsonic Boards
    Is there anyone out there who can help me out with this?
    Skydiver
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I would replace all caps 680uF and higher. Caps under that value are made from a different electrolyte formula, and are not known to fail. Everything above 680uF, replace it!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • skydiver
        • Jul 2004
        • 3
        Thanks! I just need to source them out here locally. I may just buy them from the guys here at badcaps. Do they sell them a-la-carte?
        Skydiver
        • qwerty99
          Xbox 1.6 Motherboards and Polymer Capacitors
          by qwerty99
          Hello!
          I need to change the capacitors on my three original Xboxes.
          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
          06-26-2022, 12:53 AM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
          by sam_sam_sam
          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
          After all of...
          07-13-2024, 08:14 PM
        • Ady2017
          Are there any datasheets available for Elna RJG capacitors?
          by Ady2017
          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
          05-25-2025, 02:19 PM
