Nady XA-300 Amplifier
  • bluto
    • Oct 2007
    • 557
    Got this one thrown my way because it was dead. The fuse was good but there were absolutely no signs of life. I cracked it open not knowing what to expect. At first glance there was nothing grossly wrong looking. I partially removed the power supply and started probing around on the primary side. It didn't take long until I located a disc shaped component that looked a little toasty. It turned out to be directly in series with all the input filters. However there was no continuity across it. Handily, the manufacturer printed the part number on the silkscreen.
    It turns out to be a 7A current inrush limiter/thermistor. Digikey to the rescue! Three days later the part is installed and the amp came back to life.
    The pics show the old and new parts as well as the internals. Although not visible, the part in question is near the back of the chassis between the right filter capacitor and the yellow capacitor seen just above it.
    Digikey part number: http://search.digikey.com/scripts/Dk...173-nd&x=0&y=0
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Nady XA-300 Amplifier
    I had to fix one of those a while back. The two big caps on the power supply secondary were bulging, and the B+ was a few volts too high. Also replaced a couple small caps on the output modules. It's been running fine since.
    If I recall, this amp is 100W per channel into 8 ohms.
    • bluto
      • Oct 2007
      • 557
      Good to know, thanks! On this one the caps all looked fine. This was a charity job for a local KC hall type place. It came to me dead and was returned not dead so they got what they paid for. If it breaks again I'm telling them to get a new one.
      • Caryw
        • 9
        I know I am bumping an old thread, but I have this exact amp and it worked fine but now goes into protect mode as soon as the power is turned on. The fans spin for about 2 seconds then powers down.
        All Nady will say is that it is a bad relay and want 70 to fix it.
        any idea from looking at the pictures above, where the protection circuit relay is? Nothing looks bad or out of place on mine at all.
        I have randomly unplugged everything trying to nail down where the problem is but it just goes straight to protect.
        • bluto
          • Oct 2007
          • 557
          I'll let you know if I get my hands on this one again. The one that I fixed has a twin brother in the rack, so I am sure that eventually I will have to work on one of them again.
            I am surprised that they did not use the relay to bypass that in-rush limiter a few AC cycle after the caps are charged up, that way the Inrush limiter will be used only during turn on, this will also reduce current limit compression, otherwise it will get pretty hot, I never design inrush protection circuits without the relay, may be they try to safe money, I also wonder what the resistance value is when the Thermistor cold and warm.
            • bluto
              • Oct 2007
              • 557
              This particular one was 50 ohms cold and according to the datasheet it approaches zero when warmed up. I agree it seems like a poor design, but then again this was not exactly a high end amp. Your sentiments about cost cutting probably play into the design.
                You mean 5 Ohms, so worst case max current at start-up will be about 120V/5 Ohms = 24Amps.
                • bluto
                  • Oct 2007
                  • 557
                  Yes that's right, 5.0 not 50. It can't do that much. I thought about just bridging it for a few minutes...
                  • Jukie812
                    • Jul 2017
                    • 2
                    Mine is doing the same thing. Nothing is burnt looking and the caps check out fine. As soon as I power on it goes to protect. I was running 4 ohm mono. What do I do next
                    • lbfire
                      • Feb 2021
                      • 1
                      • us
                      I had the same amp go into protect mode moments after I turned power on.
                      The lowest hanging fruit is the power supply.
                      1. I did a visual inspection of the electrolytic capacitors that might be bulging, fans that do not spin, then burnt marks, odd looking component shapes that don't look normal, and/or blown components. Found nothing.
                      2. Next I took a look at the outputs and a visual on the output board. I took an ohm meter and check for a short or a near zero reading on the output terminals. On the XA-300, you can disconnect the output boards (they have connectors) and check them independently with an ohm meter. I quickly found it was channel 1 that had a shorted output. I ohmed each output FET and found my shorted FET very quickly. I only found 1 bad FET. The output FETs are IR (International Rectifier). Unfortunately, IR was bought by Infineon. I couldn't find an original IR FET, so I stuck a Vishay FET in there. The gain pot sensitivity seems to have changed a bit. I probably should have replace all of the FETs with Vishay for uniformity on the gain. I might do this in the future.
                      • petehall347
                        • Jan 2015
                        • 4423
                        • United Kingdom
                        yes change them all and check/reset bias current after
                        • MrCommunistGen
                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                          by MrCommunistGen
                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                          07-12-2021, 05:11 PM
                        • jinu_j
                          How to test Subwoofer Amplifier with only a multimeter
                          by jinu_j
                          Hi Folks
                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                          Problem
                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                          Any advice would be appreciated...
                          08-29-2024, 02:05 AM
                        • UserXP
                          Mackie CR4 amplifier no sound
                          by UserXP
                          Hi, people.
                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                          10-17-2020, 05:06 PM
                        • waspie
                          Aiwa GX-770 Amplifier Protection Circuit
                          by waspie
                          I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                          I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                          It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                          11-29-2022, 09:58 AM
                          TDA2822M Amplifier Datasheet
                          The TDA2822M is a monolithic integrated circuit in 8 lead Mini dip package. It is intended for use as dual audio power amplifier in portable cassette players and radios.
                          TDA2822M DUAL LOW-VOLTAGE POWER AMPLIFIER FEATURES:
                          ● SUPPLY VOLTAGE DOWN TO 1.8V
                          ● LOW CROSSOVER DISTORSION
                          ● LOW QUIESCENT CURRENT
                          ● BRIDGE OR STEREO CONFIGURATION
                          Data 2003...
                          10-07-2024, 05:41 AM
