Old 01-02-2011, 02:55 PM   #1
Turco Chips
Default LG 50PG20 no picture
Hello all,
I have a 50" LG plasma model 50PG20 that, while watching tv, the screen suddenly went black. The sound continues to work though. I have taken the back panel off and when I turn the TV on, there is no sound coming from any of the boards - no buzzing or anything.
I have read that this could be either the YSUS or XSUS. I am typically a DIY'er, but wanted to know:
A) How can I troubleshoot to find out which one is bad?
B) How difficult would it be to do the repair myself?
If ya need any more info from me please let me know. Thanks for any and all replies!
Turco Chips is offline   Reply With Quote
Old 01-02-2011, 09:24 PM   #2
retiredcaps
City & State: Canada
Default Re: LG 50PG20 no picture
We usually want clear focused pictures attached and posted on this forum (don't post inline). Pictures should show the overall TV in the back and then each board individually (as close to 2000x2000 resolution).
You will need a multimeter at minimum to troubleshoot.
Look for your TV at elektrotanya.com for a service manual.
The repair can range from a simple blown fuse to replacing boards to soldering SMD chips.
edit: Another hint. Start reading through other threads in the "Troubleshooting TVs and Video Sources". Pay attention to the first response post from PlainBill. He wants to see pictures in a certain format and look at his responses on how to troubleshoot.
Old 01-02-2011, 10:17 PM   #3
Turco Chips
Thanks I'll get working on getting those pix taken and posted. 'preciate the reply!
Old 01-05-2011, 07:59 PM   #4
cadiman
City & State: chesterland Ohio
If you have sound the power supply is not in protect mode. Check buffers (left side of tv) small 1 inch square chips for burns or pin holes. These may be hard to inspect if they have heat sinks on them. Do not be near these with the tv on (high volts here).
I think these tvs (mosfet driven not chip driven) have alot of power supply problems and less driver board issues.
I would check all v per the panel specs (upper left or right on pdp).
cadiman is offline   Reply With Quote
Old 03-15-2011, 02:13 PM   #5
waximoff
I joined the forum cause almost all of my Google queries led me here. I had the same problem with my 50pg20 and am trouble shooting..
I am way out of my league I'm finding out! lol I figured I'd start with the fuse.. Where is it located?? Is it hidden or look like something other than a fuse I'd expect to see?
waximoff is offline   Reply With Quote
Old 03-15-2011, 02:26 PM   #6
rayrod81
City & State: Colorado
To be honest if you can't identify fuses on the board then you should not even attempt to test or fix this tv. These plasma tvs have high voltage throughout and if you make a mistake you could damage the tv or more importantly you will seriously injure yourself. You would be better off taking it to someone qualified.
rayrod81 is offline   Reply With Quote
Old 03-15-2011, 02:30 PM   #7
PlainBill
PlainBill's Avatar
City & State: Phoenix, AZ
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Refer to post #2 above. Confirm that you have sound with no picture.
Trying to assist without good pictures is a waste of time for both parties. Start with one over-all picture of the TV with the back cover removed. The sustain boards are on the left and right side of the TV. Closer shots of those would be helpful. Also, on the back of the plasma panel is a white label with various voltages. For extra credit, include a picture of that, too.
And don't post in two threads!!! It tends to get you ignored!!
Forget it. You don't have the same problem as the OP. $@!@$!@#!! hijackers.
PlainBill
Old 03-15-2011, 02:33 PM   #8
waximoff
I hear what you're saying. All my experience is on computers. I'm aware of the dangers and was definitely careful. i guess i was just hoping i would see the fuse and It could have been an easy fix. I found this while searching and was looking for that.
http://cgi.ebay.com/LG-50-55-PLASMA-...-/180631463251
Old 03-15-2011, 02:36 PM   #9
waximoff
thanks plainbill. I started that other one after i posted here so I could explain the symptoms. There is definitely a wealth of knowledge here and was just anxious.
