NTC Temperature probe/sensor
    Hi Guys, I'm sure most of you know the answers to my question, so please help if you can.
    I've got a washer/dryer that doesn't dry, it has 2 thermostats both of which have continuity, it also has 2 NTC temperature probes/sensors (thermisters?) neither of which have continuity. I think the NTC's are faulty, am I right or wrong?
    Also 1 of the NTC's connector plugs has both wires snapped off, does polarity matter here?
    NTC = Negative Temperature Coefficient, so resistance decreases as temp rises, so room temp should have higher resistance I think?
    Hope you can help.
    Dave
    Re: NTC Temperature probe/sensor
    If open, that is more likely failed. From i test and learn it should show reading on resistance, it is about 4 to 5 ohms. no polarity. maybe the others know better. correct me if im wrong.
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
      NTC thermistors typically have a resistance of 10k or so at room temperature. They are not polarity sensitive, and if you have ones that are little copper blocks with 2 black leads coming out thet are pretty common spare parts. You are right in the temperature and resistance reading.
        Thanks guys, just as I thought.
        I will pick up the parts on Monday.
        Looking forwards to dry clothes, it's a bit chilly here
          Ok. I have a fully working washer/drier again
          The temperature probes that I thought were faulty actually work perfectly, I had tested them with cheap 830 multimeter I keep at home, I tested them again at work today with my Amprobe meter and they were fine.
          The problem was just failed wire connection to one of the probes
          The moral of the story is don't rely on cheap & nasty meters.
            that 830 meter about $3.5 on my town. btw what resistance reading that you got on NTC?
            you forget one thing about moral of the story. always keep the eyes for loose connection or solder joints
            Best Regards
            Rudi
            Thank You
              Ha, yeah the 830 meter I've had for 3/4 years now, bought 2 for £5.00, 1 blew last year. It usually only gets used for checking voltage on laptop charges, I use the Amprobe for everything else.
              As for the loose connection, my only excuse is my stupidness
                Forgot to say, the resistance on the NTC probes at room temp was 7Kohms on both.
                  thanks. im curious about standard ohm values for that components. it looks like the standard value about 10k like seanb advice.
                  Best Regards
                  Rudi
                  Thank You
                    Hi, one sensor was 6.7k the other 7.1k, the room temp was a cool 15c at the time and as I warmed the sensors in my hand the resistance dropped, so to get a reading of 10k it would have to be very cold indeed.
                    Of course different sensors will have different values.
                    These are to parts we are talking about.
                    http://www.ransomspares.co.uk/parts/...-ntc/79397.htm
                    http://www.ransomspares.co.uk/parts/...-ntc/79396.htm
                      it will different here as room temp about 31 degree celcius here. nevermind about standard values. i forgot that we are in the different partof world. lol
                      Best Regards
                      Rudi
                      Thank You
