Macbook Pro 13 A1278 EMC2555
    Hi Macbook wont turn on fan just on and off ,have green light on charger ,
    Re: Macbook Pro 13 A1278 EMC2555
    try making a SMC AND/OR PRAM reset first of everything , then let us know , in case you dont know how to do it
    SMC reset require no power on board , no battery and dc attached to machine , for 40 second , during this time press a few times on off button .
    pram reset - press command + alt +p +r and keep pressing does keys while you press on off , keep the keys pressed , once you hear the reboot and second chime noise , release all keys .
      It not work When I connect charger it constant on off but when is on battery when I press power button makes only 2 sec fan spinning and thats all,black screen no post no beep
        mainboard code ? 820-xxxx ?
          Hi its 820-2879 Intel i7
          What Im was thinking that problem is one of the current sensing capacitor ,because its cut power just second after start
            Sorry correction about logic is 820-2936-B
              voltages on bios pins ?
                3.3v
                  wich pins have 3.3 ?
                    I have the similar problem, same board...
                    It came with PPBUS_G3H shorted to GND at Q7035.
                    I have changed Q7035 ang got green light and fan as well.
                    But unfortunately I have no display, chime, anything...
                    Also tried to power on without RAM and it runs in same way, no beeps...
                    When I plug the charger with battery inserted, green light go off after couple of sec and no orange light came on. So I have SMC_BC_ACOK at U6901 without battery and not with battery connected.
                    I tried with changing U7000 - same...
                    On BIOS i have 3.3 at pins 1,2,3,7,8.
