Fixing a Philips 50PFP5332D/37. The power board had a blink code 8 for thermal. Checked the thermal resistor and it checks out fine lowering the ohms when being heated. I can't find anything on this TV as far as repair manuals so I am at a loss. There is no standby voltage. Any suggestions would help.
Philips 50PFP5332D/37 8 blink code (thermal)
Re: Philips 50PFP5332D/37 8 blink code (thermal)
Caps around thermal show as good. Transistor doesn't show as stuck open but I can't open gate unless put 9 volts or more on it. Even then only stays open for a second. Bridge rectifier shows that it is working only on last pin reads double the ohms as the rest.
