I have a problem with lights on 2232bw...
I changed 25/330 cause it was bloated...
Tried google on the problem seems like common... and found that 25/820 are defective in this case... so i changed all 5 of them with 25/1000...
Problem is still here...
Another suspect was wires on lamps... tried to connect lamps from 3 diferent displays with same result...
I found that there are some litle capacitors on the board could that be the problem and how should i proceed?
I can send some pictures but not high res...
