Hi all! I have a Samsung Syncmaster 245bw which has the common flickering/horizontal lines problem. I've gone through the forums and found many threads on this monitor, most similarly to my problem this one.
Here's the whole story:
Before starting, The monitor partially worked, backlight present and flickery lines across the image. When I opened it up I saw that CB809 and CB876 were bulging, so I replaced them (along with the also known to fail CB872) with FM caps. I also tested the 68 ohm resistors which commonly fail on this monitor, and all were fine. When I reassembled it, the monitor wouldn't turn on at all. No lights anywhere. The 5v rail for PS_ON reads ~3v, but switches between that and 2.5v more or less at random, so something is clearly wrong leading to there. Furthermore, connecting it to PS_ON doesn't turn the other rails on as it's supposed to, but I think the problem is happening at some point before that.
Here's where this gets odd: I replaced the FM caps with the old bulging caps, and it partially worked again with the flickery image, but an image nonetheless. I thought I may have had some bad FM caps, so I replaced them again with new ones, but that wasn't the case, as I'm back at ~3v. The revision of the board I have doesn't have much of that partially conductive glue that some have, but I removed some of the glue on the board anyway as I wanted to eliminate that possibility.
Where do I go from here? I don't understand why the blown cap produces an almost working result but the new one doesn't produce the correct output at all.
Thanks in advance!
Thanks in advance!
