Hey guys -
AT is certainly too short a term to plug into a search!
I was wondering about some of you guys that work on AT power supplies and if your approach, concerns, etc. are different than that of an ATX power supply.
For details behind the reason for my question, see below:
I just rehabbed a 486 motherboard that had a leaky battery. It took quite some time to get the board ready to test, and now I am testing it inside the original case. The damage from leakage wasn't bad. It ended up only needing three jumper wires in the keyboard area, and the -12V trace had to be partially rebuilt. Speedsys (a benchmark program) runs fine. Unfortunately, I am encountering some freezes, graphical glitches, and reboots after less than a minute with the game Wolfenstein 3-D. It could be bad RAM, bad video card, bad BIOS timings - who knows.
Yeah. It's old. 486SX-33, 8MB RAM, 250 MB HD, VLB 1MB video, and I/O card. No fan or heatsink (as it has run for years).
1: Power ready gets up pretty quick. I see it cross +5V, and it (along with the +5V wires) settles into 4.94 or somewhere near there.
2: No electrolytics on mobo or video card, btw. Video card has tantalums only.
3: AT Power supply is a DVE DSP-1454P. I may adjust my space on the workbench a bit so I can remove it from the case and take a peak, however I don't have any reason to suspect it - do you? It just recently turned about 24 years old.
I have a lot of diagnostic swap/replacement/testing to do. Thought I would clue you guys in on my endeavor. Meanwhile, I gotta start digging up extra parts.
