hp 630 totally dead
    hp 630 totally dead
    hello all
    how are you
    i got a bit of trouble and im asking for help
    got here HP630 with UMA vga
    unit came with smashed LCD and was replaced
    it was working untill battery was drained then turned off
    tested with two good known chargers, not working
    not even led on dc jack
    found schematics, ordered and replaced U1001 (TPS51123) since it was heating much, but all the same
    then upon examining found short on Q1003 (P1203) so i replaced it with FDS4406 and also Q1004 replaced with FDS4406 since thay are near
    still same result, but no more short on fets
    now i have shorts on CE2002 and C1011 but when i take them out thay measure good and shorts remain on pads so short must be elsewhere
    im so bad at this pls help if you can
    sch attached
    Im Back... sort of...
    Re: hp 630 totally dead
    jp1002, jp1004 and jp1007 if any connected. If so open joints one for one and see if presumed short on c1011 disappears, then from there search which power rail is affected.
      hey Donald , tibd is kind right , first does capacitors that was getting hot , belong to wich rail ? if its 19 volts rails , then inject 19 volts on the places you usually found the short . remove all of them who get hot "shorted" after removing all shorts time to see all S3 and S0 for outher small short or malfuctions or possible not ! if you need help let meknow
        ohhh wait , c1011 is on 3 v line , so remove the capacitor and chek the coil of 3.3 volts and see resistance to ground ( one prob on the coil and another prob on the ground , start from 200ohm and if it gives 1 " infinite" start growing the class value ohm and let us know wich the resistance you got .
        and btw wich is the ce2002 you are talking about it does not exist :P
          thank you both, i will try that
          it was a typo, its not CE2002 its CE1002 and cap C1011
          il give details a bit later, but tnx for tips, this will continue...
