I have an Acer X241W that has stopped working. The computer detects it, the power light stays green, but no image on the screen. I tried shining a light to see if there is an image on the screen and no backlight, but I couldn't really see anything.
I disassembled, and the power supply is putting out 12v and 5v on the connector that is marked. There is another connector going to the inverter that has 7 pins but not clearly marked which is which. The board mentions outputting 12v, 5v and 19v. I am assuming the 19v is going to the inverter.
I inspected Caps for bulging/leaking, and do not see anything definitive. The only thing that looks weird is the transformers on the invertor have bubbles around them, not sure if that is normal. There is also one spot on the power supply that is slightly discolored from heat.
Wondering what I should check next. I have another identical monitor that is working so I could swap a few of the boards to do some troubleshooting, but opening the plastic clips on this was kind of a pain and I broke a few of them... Not sure I want to risk breaking a working monitor to fix this one.
