Have the opportunity to buy this for real cheap. Does the description indicate Main board problem or panel problem or tcon problem. I would think the randomness of things would mean an ok panel. If you notice the Vizio 1st picture has repeating pattern.
Vizio smart tv 70 inch
Re: Vizio smart tv 70 inch
2 revisions, one with T-con board, the other is built into the unit.
http://www.shopjimmy.com/sharp-runtk...-con-board.htm
Shopjimmy pretty much summed it up in the description. Seems to be a bad panel.
IMPORTANT: The following picture symptoms indicate a bad LCD panel, and NOT a bad T-con board:
-One side of the picture is darker than the other
-Picture has horizontal line(s)
-A dark, cloudy spot spreads across the picture
Installing a new T-con board in a panel with one of the defects above will result in damaging the new board.
Look for the ZH stamped on the board.
