iiyama ProLite E481S - No Power
    Picked up 4 monitors today so I thought I would share my experiences with them.
    First up was was the iiyama ProLite E481S
    Advertised Issue : No Power at all
    Taking the monitor apart ( Regulars may skip ) : There are 2 caps on the left and right of the stand where it attaches to the monitor these are easily removed with a flat headed screwdriver. This reveals 4 screws that need to be taken out to remove the stand.
    There are then 5 screws around the back of the monitor 2 small at the top and 3 larger ones at the bottom which need to be taken out. The monitor then needs to be carefully pulled apart from the bottom then down the sides which allows you to pull the back off releasing it at the top.
    2 screws holding the metal cover on need removing to reveal the boards.
    Testing : All fuses checked on there were 3 in total and the big filter cap measures 330V + when turned on so I knew the juice was getting there. I did notice 2 badly blown caps at the top of the board.
    C914 - 1000uf 16v
    C915 - 1000uf 16v
    I didn't have any 16v caps so I used a couple of 25v ones instead.
    Once these were fitted I gave the monitor a quick test and it fired up fine. I then put it back together and its been on all the time I have been writing this out so that seems to have done it.
    Just a quick note on this too. It took ages for the main filter cap to discharge itself. I know veterans would never take a risk playing with the board without checking that its discharged but for all other newbies make sure the board has fully discharged before you start to handle it.
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    Re: iiyama ProLite E481S - No Power
    Congratz for your new monitor.
    There're easier ways to discharge the main filter cap, like using a screwdriver, the leads of the MMD or a resistance.
      Regarding the screwdriver, see
      http://www.repairfaq.org/REPAIR/F_sm...ml#SMPSFAQ_019
      --- begin sig file ---
      --- end sig file ---
        I use aligator clips with my multimeter probes and clip them onto the large capacitor and watch it discharge to 0V DC before proceeding to work on the board.
        Some ATX power supplies can hold a charge for a long time too.
          Do you have the proper fluke ones? I want to buy some but not sure which ones to get can you point me in the right direction?
            1) No I don't. Since I buy all my Flukes used, I have never gotten the real ones (part number Fluke AC72).
            2) These generics should work for $3.99. The quality of the plastic will probably be not as good as the real Fluke
            http://www.ebay.com/itm/280777695195
            Free shipping to UK too!
            3) If you want to spend $2.50 USD (free shipping to UK) more, you can get these
            http://www.ebay.com/itm/230769554721
            These ones are meant for the Chinese market Fluke 15B/17B
            I would probably get the Fluke AC10.
            4) Another option is mini grabbers. See
            http://www.ebay.com/itm/270943928888
            I'm thinking about these for troubleshooting ATX power supplies which are very cramped.
              This is assuming the Fluke AC10 will fit the test leads that you have.
              Some test leads are more fat/skinny than others.
