Re: Acer x193w with Darfon B092-XXX inverter - assistance needed! [lotsa pics!]
You've got a bad habit of taking close up shots rather than a single all - over shot. I've got a problem linking the various pictures to together. But the first picture on this page gives me all the information I need.
This is pretty simple. You MUST have the power supply / inverter hooked to both the CCFLs and the logic card. You also must have access to the back side of the power supply / inverter. You should have the front panel hooked to the logic card. It is desirable, but not absolutely necessary to have the LCD panel hooked to the logic card.
In situations like this I like to take a piece of the pink foam that usually comes with motherboards and use that as an insulator between the cards and the back of the LCD panel. I'll then hook the ground traces of the power supply to the back shell of the LCD panel. A primary consideration of this arrangement is you must avoid contacting the area of the power supply that is at 165 (or higher) volts. That would be uncomfortable.
PlainBill
Originally posted by HexInverter
View Post
PlainBill
