What type of sensor connector is this where can I buy some
Here are some reason photos of this connector
Thanks to anyone that can help
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
Re: What type of sensor connector is this where can I buy some
Your pic looks like "M12 Eurofast" 4-pin female, right angle.
Those are a common European connector used in industrial automation and sensors, fieldbus.
Not popular in North America because they are expensive and the pins break off easy.
Digikey has some by Amphenol, TE, I usually get them from Turck
There are 4-pin, 5-pin (shield), molded/sealed cordsets for water proof, zillions of variations on them.
Thank you for the info
9 PC LCD Monitor
1 Dell Mother Board
It's a connector for a Siemens induction sensor.
Probably: 3RX1-502 or something similar.
See here in the catalog:
Thank you for the info it is a m12 connector
9 PC LCD Monitor
1 Dell Mother Board
