It's a Hanns G HW173. My boss let me have this failed monitor, thought I'd see if I could fix it. The power light would flash green, and nothing would display. When I tore it apart and found several bulging caps on the PSU and knew what I had to do. Ordered replacement samxon from this site and gave her a try.
In case anyone's interested in my technique, I did it as follows:
1. Add some solder to the pins on the underside of the PCB
2. Heat one side up, carefully begin to work the cap out
3. Heat the other side up, keep working it out. Repeat this until it comes out
4. Use a solder sucker to take the old solder out
5. Put the new cap in, hold it in place with electrical tape
6. Cut the ends, apply solder
7. Clean up brown gunk with denatured alcohol solvent and an old toothbrush
Fired the sucker up and it worked great. First time I've soldered a PCB before too.
