Board view file for Apple 820-2877-b
    Hello
    Is there any way to find board view file for 820-2877-b year 2010?
    I have found an earlier one but not this.
    Thank you
    Re: Board view file for Apple 820-2877-b
    try to search before make a new topic
    https://www.badcaps.net/forum/showthread.php?t=42038
      It was the first think that I did and couldn't find it..
      Can you tell me where is 820-2877-b since I don't see it?
      The one posted here has many differences in board layout..
        I'd like to resurrect this thread since 820-2877 and 820-2877-B are really incompatible schematics with each other.
        So can anyone post 820-2877-B schematics and its boardview pretty please?
          This should be ok.
            Originally posted by diif View Post
            This should be ok.
            That's it!!! Spot on. You are a life saver mate.
              This should be ok.
              Thanks!!!
                thank you very much
                  thank you so much
                    thanks
                      thanksa
                        Thank you
                          Thank you very much .
                            Thank you !!!
                              The attached file is actually 820-2877-A . which has a different layout
                                Schematics should be good. Boardview is for 820-2567 which looks similar but has several area with a different layout. Check if the one in this post is the correct one:
                                https://www.badcaps.net/forum/showpo...8&postcount=19
                                  This should be ok.
                                  Thank you very much, my brother
                                    thanks!
                                      Gracias.
                                        thank you so much
