Got this monitor recently, it was non-working initially, on power-up, would get a flash from the graphics board info about no RGB signal, and the green power light on the front, flashed on and off continuously. No backlight was coming on.
Opened it up, and found 3 of the 6 Capxon's in the top right area of the powerboard bulging, so got all 6 of those replaced today, and the panel is now coming on with video signal and backlight.
There are vertical lines the whole way across the screen though, difficult to photograph, but I've attached an image anyway. Halfway across the room, you wouldn't notice them, but at working distance, they're quite evident. The lines seem to have a reddish tinge to them.
Anyway, some of the voltages off the power board aren't quite perfect, and I'm wondering if these overvoltages could be causing this issue? Here is a list of the expected voltage, (measured voltage whilst panel is on), and {measured voltage when the panel is off} (may be significant?).
24V (24.68V) {27.03}
12V (15.74V) {17.97}
5V (5.05V) {5.05}
-8V (-9.11V) {-9.49}
Any pointers as to what I need to check next?
5V (5.05V) {5.05}
