Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 06-08-2017, 05:01 AM   #1
appie1206
City & State: Nijmegen
My Country: netherlands
I'm a: Knowledge Seeker
Default How can i locate the short on my Asus N73S
Hello all..
I have A asus N73s when i plug the power cord in it wil short...
I want too know Where can i inject the voltage too trace where the defect component is
I do have a dc power suply I can adjust the voltage and the amp also..
Can sombody help me please!!!!
appie1206 is offline   Reply With Quote
Old 06-08-2017, 03:33 PM   #2
cpt.charlie
City & State: Torrelavega
My Country: Spain
Line Voltage: 230VAC 50Hz
Default Re: How can i locate the short on my Asus N73S
Connect the power at the DC input to simulate the power supply, but first try to locate the schematics, likely you have a short at +B rail. (also check the pcb around the dc-jack positive pin if the jack is directly soldered to the board)
cpt.charlie is offline   Reply With Quote
Old 06-09-2017, 12:33 AM   #3
appie1206
I was searching for one on the internet the schematic.... I cant find it unless you pay 10 dollar for it do you know a Good website where i can find it? I do know for sure i have a short too ground.... Because when i set the multimeter in beepmode en i touch with my probes th dc jack + with ground its shorted... it beeps
Old 06-11-2017, 10:16 AM   #4
cpt.charlie
My Country: Spain
I guess you have the Asus N73SV.
Old 06-15-2017, 11:07 AM   #5
appie1206
Quote:
Yes it is a n73sv....can you maby help me with it.? Where should i inject the voltage and how much?
Old 06-19-2017, 03:36 PM   #6
cpt.charlie
My Country: Spain
First you need to determine where is the short, remove JP6001 and JP6002 and with a DMM check the resistance at both sides, maybe PD6000 (TVS diode got shorted), you need to isolate parts of the cirtuit to discover the short.
Old 06-23-2017, 12:57 AM   #7
appie1206
Can u mark it for me on a picture wich 3 ? When i look at schematics i dont understand it... im handy at some things but not with schematics
Old 06-23-2017, 07:14 AM   #8
appie1206
pic
Old 06-23-2017, 10:15 AM   #9
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Quote:
Top left in your photo.
diif is offline   Reply With Quote
Old 06-23-2017, 11:21 AM   #10
appie1206
Quote:
So i need put the power on those 2 solder joints?
Old 06-23-2017, 03:46 PM   #11
diif
My Country: England
No, he's suggesting you remove the solder at these two points which then reveal a break in the trace and you can test which side has the short with your multimeter.
Old 06-26-2017, 11:55 PM   #12
appie1206
Ok i will trie it... on wich mode should i set the multimeter im a newbie at this..
Old Yesterday, 10:07 AM   #13
cpt.charlie
My Country: Spain
OHM range or diode testing will do the job.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
