This the same board as the other post how ever this one has more problem with it
Dell 1703 FPS Board # 79044120 Dead no life #2
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
All of the mosfet that are taken out by bad capsTags: None
Re: Dell 1703 FPS Board # 79044120 Dead no life #2
Need to what is the real value R858
One R858 is open which is next to U850
Also every thing work but only if you have two power supplies one 12 volt and one that 4.5 volts then you see it workLast edited by sam_sam_sam; 09-11-2011, 11:02 AM.9 PC LCD Monitor
1 Dell Mother Board
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
This a SOP chip and I can not read the numbers
I made a mistake in model # it is not E1703 it is a E1706
How ever I have both models9 PC LCD Monitor
1 Dell Mother Board
The only way that I will know for sure what the value of this resister is IF i can get one of these board to work ONE note I do not have any CLF tube that good for these two monitor at this time I do have two other screen that do have good CLF tubes
Like said in the other post I know this board has more problem I may just use this one for parts IF I do this I will cut the inverter board part off the main part of the board and use it to test CLF tube9 PC LCD Monitor
1 Dell Mother Board
I WILL use this one for parts IF I do this I will cut the inverter board part off the main part of the board and use it to test CLF tube
It' getting cut apart SOON9 PC LCD Monitor
1 Dell Mother Board
