Hello everyone, I'm trying to fix acer ES1-511-C29D that doesn't have image. I have found schematic for board LA-B511P, but it's hard to measure components because lot of them aren't labeled. Does anyone have boardview for this?
LA-B511P Boardview (Acer ES1-511)
Re: LA-B511P Boardview (Acer ES1-511)
It's me again, I'm having problems with this board. All always on power rails (+1..0ALW, +1.8ALW, +3VALW, +5ALW, B+) are present when I power this board off bench power supply. With it just plugged in it draws around 30mA. When I press power button, current draw jumps to around 150-170mA for a few seconds, then returns to 30ma. Power LED lights in same pattern(turns on, then off after few seconds). This cycle repeats three times, after that board shuts off.
When it starts turning on I can measure +3VS and +5VS, from which other rails are generated. Problem is with SUSP(#) signal, because it shows up then turns off, and because of that system power rails turns off and on.
What controls SUSP and SUSP# signals, and why doesn't it stay on completely? I'm new to board repairs, so I would really appreciate some help with this
Hi
This could be many things ....Bios ? check dcjack led lighting up... see if caps work or if you plug something in usb if it lights up like a keyboard or mouse a bad memory socket try one stick at a time see if it come alive if yes double up the memory on the good socket and call it a day.. Cpu missing 32mhz crystal single missing core voltage not correct
Reply back ?
Techman1025
After more measuring I'm missing +1.35V, +1.35VS and +0.675VS, all generated by same IC(PU501 or RT8207MZQW). I've noticed that that there is 0.4V on pin 9 of that IC with label TON when board is just plugged in, but when I turn it on it goes to 0V. That pin is pulled up to B+, which in this case is 19V, via 887K resistor. There is also no output from that IC on pins UGATE and LGATE, which drive two mosfets.
SYSON behaves just like SUSP, turns on and off
I have ordered CH341 bios flasher and adapter to DIP. As it is from china, it's gonna take a month or so to arrive here. Maybe I will try something with raspberry pi or arduino, it looks like it's possible to flash bios with those two. Until then, thanks for your help
Originally posted by ivmilicevic View PostI have ordered CH341 bios flasher and adapter to DIP. As it is from china, it's gonna take a month or so to arrive here. Maybe I will try something with raspberry pi or arduino, it looks like it's possible to flash bios with those two. Until then, thanks for your help
Techman1025
Yes, SPI ROM can be flashed using a Raspberry Pi. Connect the chip to the Rasp's SPI bus (you'll probably need to desolder it first) and use 'flashrom' to dump&flash. Works great, you'll find more info on the win-raid forum.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
