Hello fellow technicians
i got this notebook from somebody.
it became mine, so i will like your brain if you can help me to solve this puzzle .
the board code its in the picture.
i can`t find any schematics for so if you got one please share it.
p.s. i saw MSI uses this board to.
let me begin .
somebody try to change the screen and ... yes they are not PROS.(connector pic)
-there is voltage on power button and it goes down when its pressed.
-no voltage on bios.
-nothing its heating.
-if i take the bios battery out and i insert the adapter its auto starting.
I can swap the the LCD connector but i will try to fix it before.
I never try to install ram on it but i`m 95% it will boot because i saw this case once but i did not even knew how to solder properly then.
the Q: did you saw something like this? was the kbc bad?
thank you
let me begin .
thank you
