LCD PANEL electronic board
    I would to ask about LCD panel repairing.
    LCD panel have an electronic board, but I dont know, how does it calle.
    Have you any reason, where can I download schematic diagram for these electronic boards?
    I am trying to repair: MT190AW01V5 LCD panel from Samsung LCD monitor
    Thank you very much.
    Re: LCD PANEL electronic board
    Try here http://elektrotanya.com/
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
      It is called T-CON board that is intergrated with the LCD panel assembly. I do not think anyone can ever get the schematic for any T-CON board, all you can do is the check the voltages and the output of the voltage regulator, see if it has any burnt or shorted out components.
        I have got a cracking issue with a monitor t-con issue for you later budm. I will try and get some pic's after to see if you think it can be revived.
