OK, here it comes. Version 0,98, still missing a few loads and switchers. Will be able up to 520 W on 12 V, with 75W bulbs and modifications (much thicker conduct paths, couple extra connectors and with twice the airflow) up to 975 W.
Simple PSU load
Simple PSU load
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Tags: None
Re: Simple PSU load
Why quick tests only? I have fan with at least 250 m^3/h (I have no idea what it is supposed to blow at 16 V really, similar models I found are 350 m^3/h rated, and I am connecting it between +5 and -12 V) blowing on this thing It is being connected to that cinch laying there. For 450+ W loads I can add two extra 9cm fans with 150 m^3/h each. And for 1 kW of load I have found Italian vehicle-type 12V fans with some 800 m^3/h airflow
I may add few readers later, sure, on the other hand…I can test voltage one by one, right The difference it makes between taking all voltage readings at the same time and between taking it one by one is somewhere at 0,000001 % levelLast edited by Behemot; 11-20-2012, 11:03 AM.Less jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Re: Simple PSU load
Good idea. Have also been thinking bout some heatsinks if it would be too hot. Or I can just increase the airflowLess jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
Re: Simple PSU load
Originally posted by Behemot View PostWhy quick tests only?
Now days the digital loads are more in fashion, and you have more control about acting cooling over one heatsink than an ceramic resistor.
Re: Simple PSU load
You would be quite surprised how many even professional testers use high passive load inside Sure, active has some advantages, but on the other hand it's complicated electronics. Of course, I have in plan to add some active load in future, I even have the circuits here somewhere for like two years, just add heatsink and goLess jewellery, more gold into electrotech industry! Half of the computer problems is caused by bad contacts
