hi im going to attempt a repair on a imac the internal 30 pin display connector is broken
i have a new connector ready to be soldered on but i have had experience with soldering a new connector on a imac in the past the trouble i had was some of the board solder pads on the board as they were tiny & would not take the solder even with flux and 1 of the small pad on pcd came off ( prob due to too much heat on the soldering iron)
my question is instead of useing a soldering iron this would it be best to use a hot air station with flux paist instead? also i dont want to risk lifting the pcb pads again so what heat setting would you say is safest to use.
any tips or help would be gratfull
