I've bought a suspect board off of ebay, mostly because I enjoy projects and repairs.
It's a MS-7411 media live diva motherboard, which is fairly unique (I have one already which works) in that it has an add-on 100W x 5 audio amplifier.
I'd like to get this one working as a second system.
I've tested it with known working components from my good motherboard.
Ok - Tested on bench with cpu + cooler, 1 stick of ram, mouse and keyboard and psu.
All plugged in, switch on by shorting the pins on the motherboard and the psu fan kicks slightly and nothing else happens, the psu fails to start.
The green led on the motherboard is on.
If I unplug the 4 pin cpu power cable from the motherboard and switch on the board, the psu powers up, although of course there is still no post.
It reacts the same whether there are components fitted to the board or not. Anyone come across this behaviour before?
My guess is that there is a short on the board which is setting off a protection circuit within the psu, and shutting it down. Removal of ac power is required to reset.
I'm not sure that this sounds like a cap problem but would love to be proved wrong.
