I have the above monitor which was suffering the "starts normally then goes dark after 30 seconds or so" problem. I dismanted the monitor expecting to see evidence of bulged caps but found none. The only problem I found was one dry solder joint on the board connector leading to the monitor switch cluster on the front of the monitor. I re-soldered this just as a matter of course and when I reassembled the monitor found it now powers up, starts dark and then over 30secs or so comes up to normal light level and stays there indefinatelly. If the computer goes to sleep and the monitor orange light comes on then when the mouse is moved the green light comes back on and the display is again dark for 30 secs or so and then comes back to normal. I have no answers for this strange reversal of symptoms but would be grateful if anyone else had i.e. is there a common cap or transistor that affects the speed at which the monitor reaches normal light level. Any help appreciated.
John
John
