Samsung UE40JU6445K eeprom
  • stav242
    • Jan 2014
    • 61
    • United Kingdom
    i have a Samsung UE406445K, with BN94-10515S MB.
    symptoms:
    Tv starts, LED flashes 5 times. no backlights, no picture.
    checks:
    - have removed MB <> PB cable and backlights come on, LEDs and PB seems ok.
    - LED flashes in response to remote buttons.
    - have tried the shorting SDA+GND pins on the eeprom but no effect.
    ive got a ch341 programmer, have desoldered and read the eeprom. (24C512C)
    can anyone help check it / repair / or provide data to reprogram ?
  • stav242
    • Jan 2014
    • 61
    • United Kingdom
    Re: Samsung UE40JU6445K eeprom
    I've had no response.. does that mean I have not provided the required info ?
    • dskall
      • Oct 2016
      • 2905
      • usa
      Have you got 12v to your t-con? Checked voltages on mainboard?
        09-07-2024, 05:50 AM
      • max789
        Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
        by max789
        Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
        I made the following tests:
        1. Disconnected the main board from Power Board = backlight works.
        2. Connected the main board and disconnected the T-Con = backlights does not work.
        So I ordered a main board from Ebay also BN41-02156A but from...
        01-18-2024, 06:56 AM
      • Jacksoft
        Samsung 225MW EEPROM bootloop
        by Jacksoft
        I got an old Samsung 225MW TV with BN41-00825 motherboard.
        Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
        So I attached the VGA UART cable and read the debug data using a RT809H programmer:
        According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
        Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
        02-14-2025, 04:18 PM
        09-06-2024, 11:40 PM
