Ue55mu6172uxxh, bn94-12438k
  • lotas
    • Jan 2016
    • 4839
    • Russia
    #81
    Re: Ue55mu6172uxxh, bn94-12438k
    Originally posted by nikola07
    help me fix my dump.This UE65MU6172UXXH BN41-02568B
    Try.
    • Sebastijan V.
      • Feb 2023
      • 15
      • Slovenia
      #82
      It's me again ๐Ÿ˜Š It is the same TV again, with the same problem... I already fixed this 14 months ago (see page 3) and it worked until now.
      The failure came back - no red light.
      So, I tried and reflashed IC1604 again with the same SW as Mr. Lotas provided me back then. Unfortunately, it did not worked, but at least the red LED comes on and blinks each time when joystick button on the backside is switched to any position... ๐Ÿคจ
      I have read back the chip again, and saw that there is a difference again. So, lets see if you can help me again?
      Here is the timeline what I did:
      - unsoldered IC1604 and save the dump as "W25Q40CL@SOIC8_8_4_2024"
      - flash it with fixed SW that you sent me on Page 3, and corrected the Registers
      - solder it back again and did not work.
      - unsolder it again, readout and save the dump as "W25Q40CL@SOIC8_9_4_2024". the Registers kept their corrected value as they should.
      Thank you for your effort and time!
      • lotas
        • Jan 2016
        • 4839
        • Russia
        #83
        If the TV was updated with software via USB or over the network, then the contents in 25q40 also change and the old dump will no longer help in this case, why now do you have a dump in hex format and not in bin?
        • Sebastijan V.
          • Feb 2023
          • 15
          • Slovenia
          #84
          I think I updated TV the last time I was repairing it, but I'm not 100%.
          My programmer (TL866-II-Plus) has both options of saving - bin and hex. I think I left it on default - that is hex. Do you need Bin too?
          • lotas
            • Jan 2016
            • 4839
            • Russia
            #85
            Try.
            • Sebastijan V.
              • Feb 2023
              • 15
              • Slovenia
              #86
              It works! Thank you very much!
              I also went in menu to see the current SW-versions, and for the reference, they are:
              - model code: UE55MU6272
              - serial number: 0AGD3SCJA01397R
              - SW-version: T-KTMDEUC-1400.3 , BT - S (interestingly, this version is from December 2023, but I repaired this TV and maybe update it manually on February 2023, so I guess it updated itself automatically sometime)
              - Sub-micom version: T-KTMINTV-1011
              - version of e-Manual: KTMDVBEUL-3.1.3
              And I will warmly recommend the owner to sell this TV and think about other brand/model... Otherwise, we might do all over again next year. ๐Ÿคฃ๐Ÿคฃ
              • age80
                • Jun 2013
                • 55
                • Greece
                #87
                @lotasโ€‹ i have an ue32t4302ak with the same symptoms as the above people (IC1001 corrupt)
                I'll upload the rom file and if it's not a problem i would like you to take a look...
                The board is a BN94-15305R
                Thanks man for all the help you give!!!
                • lotas
                  • Jan 2016
                  • 4839
                  • Russia
                  #88
                  Try
                  • age80
                    • Jun 2013
                    • 55
                    • Greece
                    #89
                    I was pretty confident when i saw your file that it was gonna fix the TV!!!
                    Program it, solder the chip back and Voila picture once again!!!!
                    Thank you my friend!!!
                    • lotas
                      • Jan 2016
                      • 4839
                      • Russia
                      #90
                      Ok! Please!
                      • Yanleb
                        • May 2017
                        • 102
                        For writing back the IC, I use the MiniPro TL866CS. I see registers 0xFC and 0x42 instead of registers 0x88 and 0x42. Does it make a difference?
                        Click image for larger version  Name:	image.png Views:	0 Size:	24.1 KB ID:	3510331
