Samsung PN59D6500 Plasma TV issues
  • Burglicious
    • Dec 2021
    • 9
    Hey all, i have a Samsung PN59D6500 that I rescued from the dumpster and I'm trying to fix it. So the issue I am having is that the TV isnt turning on at all. I have VS,VA,VSC,VE at all the appropriate voltages. I have 3.3V at the PS-On, and 5V also. Whats happening is when i press the power button on the remote the TV has has the relays click, some pixels flash on the screen and then it seems to turn off. It repeats this until the TV is unplugged. I know that the Mainboard has a problematic EEPROM but this seems kinda like a power regulation issue. Anyone have any ideas?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung PN59D6500 Plasma TV issues
    Try freezing the nand chip on the mainboard with an upside down can of air duster. If the tv turns on the mainboard is the problem. Nick's tv is a member of this forum and he can replace the chip.
    • Burglicious
      • Dec 2021
      • 9
      They still have those chips programmed? I would've thought the stock/files would've went away long ago. By trade I'm an electronics tech, albeit relatively inexperienced with troubleshooting, however I can solder at a high level. Is there anywhere I can buy the chip and solder it myself?
      • lotas
        • Jan 2016
        • 4702
        • Russia
        https://www.ebay.com/itm/263952614219
        • Burglicious
          • Dec 2021
          • 9
          Thank you. I appreciate the advice nice to see a responsive forum
          • Burglicious
            • Dec 2021
            • 9
            Hey dude, I tried this tip and unfortunately the issue persisted. Could it be that the chip is too far gone to function at all?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              I have a feeling that all that is wrong with your set is the 3 "c106" little blue capacitors on the ymain board.
              • Burglicious
                • Dec 2021
                • 9
                Interesting, I will test and respond with the results. The weird thing with the Y Main is that the VScan voltages are perfectly fine. Do you recommend a test point I could try? Or just test those caps? And since I'm trying to use this as a learning experience, could you tell me their function possibly?
                • Burglicious
                  • Dec 2021
                  • 9
                  Ok I did some digging. All small blue capacitors ohm’d out fine, as well as had a 15vdc. I am including a video/pic of the most apparent issues I have found. On Ic1302 (which I am thinking is the issue) there is a burnt pad. The data sheet says this is pin 48 which is not internally connected to anything so I doubt it has any effect. What I’m wondering is how it burnt down like that. Maybe desoldering issue? Regardless I’m just curious what your input on these symptoms would be. I attached an Imgur link, the attachments wouldn’t show up
                  https://imgur.com/a/MLt0uuF
                  Last edited by Burglicious; 12-12-2021, 12:27 PM. Reason: Attachements wouldn’t show.
                  • Burglicious
                    • Dec 2021
                    • 9
                    So good news! I got the chip, soldered it on, and it works….. almost! Now there’s still the issue of it power cycling every 10 or so seconds. I’m thinking maybe the power board? The TV displays the Samsung logo perfectly, as with before it didnt. It just did a blank screen.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      Try the freezing trick again. It still sounds like the chip is bad.
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        https://youtu.be/pBeY1W3vF60
                        • Burglicious
                          • Dec 2021
                          • 9
                          Alright I'll try it again. I found a capacitor that I'm pretty sure is bad on the power board but I'm not entirely sure that's issue. It's reading as an open. I'll give the freeze spray another try though
                            09-07-2024, 05:50 AM
                          • Nairolf
                            Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                            by Nairolf
                            I have a Samsung DM32D display.
                            When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                            Here’s what I have tried so far:
                            1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                            2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                            3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                            From these tests, I suspect the problem might be on the mainboard. Could anyone...
                            08-24-2025, 03:47 AM
                          • bohaboha
                            ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                            by bohaboha
                            Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                            04-19-2025, 01:47 PM
                            09-06-2024, 11:40 PM
