Plasma ooops...
  • NxB
    • Feb 2009
    • 1595
    Plasma ooops...
    I got the LG plasma working and the image looked good. Unfortunately I wanted to adjust one of the voltage pots (black level) on the ysus without taking the back off.
    The screwdriver touched the case and the fuses went on both y and zsus.
    After replacing those and feeling mighty stupid I powered the screen on. At first it showed a really messed up image. It looked like windows in 8 bit color. Slowly the image faded away and now there is nothing. No OSD either.
    All the voltages are normal, the red LEDs light up on back, no protect mode. On the LVDS, one green led blinks and one stays lit. The rest only turn on at start-up.
    Any ideas.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Plasma ooops...
    Any ideas.
    Next time use a plastic 'diddle stick'.
    PlainBill
    • NxB
      • Feb 2009
      • 1595
      Re: Plasma ooops...
      Found a dead smd fuse on the video board. I fixed it but still no go. It is off a 2.5v regulator (which works). Would replacing the board fix this?
      • Wizard
        • Mar 2008
        • 2296
        Re: Plasma ooops...
        OUCH.
        Always use a plastic tweaking tool.
        Cheers, Wizard
        • NxB
          • Feb 2009
          • 1595
          Re: Plasma ooops...
          Ordered a new video board. Hope it works. It was only $30 bux. I got to use this screen for like 30 minutes before I adjusted it. What a downer.
          • NxB
            • Feb 2009
            • 1595
            Re: Plasma ooops...
            The IC whose fuse blew was the LGDT4410 IEC.
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
            • piershs
              Toshiba plasma 50WP16 wierd double image fault
              by piershs
              My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
              Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
              • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
              • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
              08-01-2020, 01:07 PM
            • Delired73
              TV LG 50PA4500 Plasma : bad image noisy
              by Delired73
              I have an issue and didn't find any solution by myself or on every forum about my LG plasma TV 50PA4500.
              Originaly the TV stopped to work and didn't want to turn ON again.
              After visual inspection, few transistors were broken, I tried to change them but some burned again, so I ordered on full new board. So, I changed the Yboard which was burned by a new one
              It now turns ON and the image and sound are present. But the image is very noisy and only visible when the room is in the dark.
              I check Vs and Va voltages...
              04-04-2021, 09:13 AM
              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
              09-06-2024, 10:56 AM
